Pista Exhaust Upgrade | Page 11 | FerrariChat
Discussion in '458 Italia/488/F8' started by dustman, Aug 13, 2019.
  1. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,645
    AUSTRALIA
    ANGELO
    I will receive some better videos soon .
    This was my iPhone. Tell you its so much better than what the video shows. You can here the higher shrill.
    Also note the valves are connected at this stage.
  2. Lagunae92
    Lagunae92 F1 Rookie
    2,853
    SoCal
    Excellent, look forward to more vids!
  3. Lagunae92
    Lagunae92 F1 Rookie
    2,853
    SoCal
    I’m not entirely sure. I’ve had 3 of them installed at my dealer. When I picked up the Pista, the remote kept the valves closed instead of open, so I I took it back immediately and they fixed it using the polarity of the valve and the magnet.
  4. SECRET
    SECRET Formula 3
    1,020
    Maranello, Italy
    Ferrari Ferrari
    Is this the Kline system?
  5. SECRET
    SECRET Formula 3
    1,020
    Maranello, Italy
    Ferrari Ferrari
    Ok, maybe that's going to be a good alternative if I can't get this system issue resolved.
  6. MANDALAY
    May 23, 2013
    14,645
    AUSTRALIA
    ANGELO
    Yes
  7. chrixxx
    chrixxx Formula Junior
    994
    Lucerne
    Chris
    I couldn't really found lots of informations about the Tubi Controlller and I wanted to give it a try and see was it does. I know a few Pista owners with No Cat, with 200 and with 100 Cells and some of them have issues and some others not. So we will see how it works and if not we gona change it. very easy :)
  8. Gh21631
    Gh21631 F1 Veteran
    9,157
    East
    There are work arounds with the cats but its hit or miss in my experience. A tune generally works though.
  9. Lagunae92
    Lagunae92 F1 Rookie
    2,853
    SoCal
    any updates to the Kline installs?
  10. Gh21631
    Gh21631 F1 Veteran
    9,157
    East
    Mine is on order + the extra one if someone here wants a deal. Hopefully it will be in soon. We also ordered one for an 812.
    Lagunae92 likes this.
  11. Lagunae92
    Lagunae92 F1 Rookie
    2,853
    SoCal
    I like your style
  12. freshmeat
    freshmeat F1 Veteran
    Aug 30, 2011
    7,284
    Shrill? What shrill...
    ShineKen likes this.
  13. MANDALAY
    May 23, 2013
    14,645
    AUSTRALIA
    ANGELO
    That's just it , its very hard to record. You have to hear it in person.
  14. freshmeat
    Aug 30, 2011
    7,284
    I hear a bark, raspy note accompanied with moderate turbo whistling...maybe I’m losing my hearing
  15. Gh21631
    Gh21631 F1 Veteran
    9,157
    East
    That's usually the case, unless recorded with the proper equipment you dont get the full effect.
  16. SECRET
    SECRET Formula 3
    1,020
    Maranello, Italy
    Ferrari Ferrari
    Alright guys, I'm going with the Novitec Inconel muffler section with flap regulation (aka fancy german name for valves). I'm also ordering the Capristo exhaust valve controller.
  17. Lagunae92
    Lagunae92 F1 Rookie
    2,853
    SoCal
    Alright! Likely my combo as well. I’d say can’t wait to hear it, but likely that will have to be the case unless it’s in stock somewhere.
    SECRET likes this.
  18. Jo Sta7
    Jo Sta7 F1 Veteran
    5,912
    Scottsdale/Pittsburgh
    Jon
    No sports cats?
  19. Shadowfax
    Shadowfax F1 Rookie
    4,066
    Australia
    #269 Shadowfax, Jul 28, 2020
    parently so. not sure what they are hoping for volume wise given the stock system is straight through when the valves open. This where the straight though needs to run through an Inconel large X too. The volume isn't going to increase without the sports cats. This has already been clearly explained to me by Kline but I'm always keen to listen to user reviews just in case the maker got it wrong.
    Truth is Jo Sta7 is that the Pista sounds pretty damn good running straight through the stock cats w valves open bi passing the muffler so any real improvement can only be had by running the straight through gas through a large x pipe and reducing the backpressure using 200 cel cats instead of 600 cel.
  20. Jo Sta7
    Jo Sta7 F1 Veteran
    5,912
    Jon
    I just don’t see a downside in replacing cats. They’re just pipes with a filter. 200 Cel will pass emission and 80% of any power bump you get (we’re only talking 20-25 hp total here) will be from the cats along with more noise. Cars ECUs won’t need a tune. The exhaust then tunes the noise.
    MANDALAY and Gh21631 like this.
  21. Gh21631
    Gh21631 F1 Veteran
    9,157
    East
    The Kline system I ordered includes the 200 cell sport cats and valve controller. To me, it makes sense to use a complete system from one mnfr.
    LARRYH and MANDALAY like this.
  22. Shadowfax
    Shadowfax F1 Rookie
    4,066
    Australia
    #272 Shadowfax, Jul 28, 2020
    The cats will only pass emission if the precious metal content is adequate to the dimension and flow rate and this is obviously where the 100's fail hence why CEL is thrown. That said you can achieve the right emissions in a 100 cel but is much more costly to do due to the precious metals and cat design. The current 200's appear to come within range of the o2 sensors but the precious metal content in the cats essentially determines this. It could be the case that they are operating on the very outer extremity of the range though as the 200's can throw a CEL i'm told which means they are very much dependent upon fuel quality. The Pista and F8 having the pressure sensors upstream also add another complication.
  23. Gh21631
    Gh21631 F1 Veteran
    9,157
    East
    Good info. I am being told by Kline there should not be a CEL with their 200 cell cats but would need a bypass or tune for the 100 cell cats. I will know soon enough as mine is on order.
    MANDALAY likes this.
  24. Shadowfax
    Shadowfax F1 Rookie
    4,066
    Australia
    Don't use the bung extensions as a friend of mine has reported these increase the chance of CEL in the Pista. He speaks from experience and, on the Kline as he has it on his Pista. Since removing them it is fine.
    LARRYH and Gh21631 like this.
  25. Coincid
    Coincid F1 Rookie
    Dec 9, 2014
    3,605
    Canada
    I find the stock sound of the Pista to be quite satisfying.
