Pista making noise | Page 2 | FerrariChat
Pista making noise
Discussion in '458 Italia/488/F8' started by Kaylie, Feb 11, 2023.
  1. lucasines
    lucasines Karting
    Apr 22, 2016
    139
    Paris
    Gilles
    Replace Rear Nut HUb Hex
    P/N Ferrari 203780
    Pozzy France and Ferrari Italy know this issue as soon you describe it.
    You can stay with this without dammage, but they can change this part during annual service.
    Mk23 likes this.
  2. Mk23
    Mk23 Karting
    Jul 20, 2025
    78
    Dude God Bless! Appreciate the thorough response from you and others. I'll take it to an indy shop next week and ask them to replace both rear nut hubs. I'm praying this will do the trick!
  3. lucasglory
    lucasglory Rookie
    Jun 9, 2024
    15
    I have the same issue on my F8. If I let go of the accelerator and let it coast, I hear the squeaking. If I slowly coast through the neighborhood, it makes squeaking sounds like an old scooter. Took it to the official dealer (on warranty) twice and they just said it's stuff getting trapped in the brakes. Learned to live with it.
  4. Mk23
    Mk23 Karting
    Jul 20, 2025
    78
    Man that’s unfortunate to hear that even at the dealer they can’t figure it out, even worse, seems like this issue carried over from the 488GTB and Pista and now went to the F8. Seriously Ferrari? Anyways, debating on whether I should have the Indie shop replace the hub nut as described above now or wait till my next service. Either way I’ll report back on this thread if and when I do it and if it does fix the sound.
  5. mdrums
    mdrums F1 Rookie
    3,745
    Tampa FL
    I've had 4 cars with CCB's 2 Porsche and 2 Ferrari and they will squeal as they glaze up from light braking and dragging the brakes like in street driving sometimes but that was extremely are for me. My F8 is 4yrs old and does not make any squealing or chirping noise with the brakes.
    I truly believe that some cars when washed/detailed are getting tire shine on the rotor. This is extremely bad because as soon as your apply the brakes it does not wipe off the tire shine overspray but the instant heat opens pours and the silicone and tires shine gets bedded into the rotor and with the brake dust accumulates the pads vibrate and cause the squeals you guys hear. I only apply tire shine by spraying onto the sponge not near the wheel...actually I use a semi gloss tires dressing that squirts out onto the sponge.
    When I wash my cars I also wash the brakes...calipers and rotors with soap and water, including the wheel barrel/inside wheel...no wheel cleaner at all. Hose off the holes in the rotors too and brake dust gets in there and they can clog up.
    I've never have any issues like I read on these forums.
  6. Mk23
    Mk23 Karting
    Jul 20, 2025
    78
    Trust me, I've done everything you mentioned. I've been reading this forum daily since I bought my car. I think I'm the worlds expert now on Ferrari chirping at coasting haha. There's some things that point to this being the brakes (chirping goes away when you brake actually) but things that don't point to brakes (chirping worse when turning left, only coming from one left sided axle, increasing with acceleration and then going away at higher speeds).
    I've washed my rotors, pressure sprayed them and even bought a non silicon tire dressing someone else recommend on this forum (probably you from years back ha). I've bedded the brakes by doing 10 stops from 80 to 20 mph. Slightly improved that night. Returned the next. Took it to the dealership for service and complained. They said the cleaned the brakes and it's gone. Came back on my drive home from the dealer.
    I've done everything and I'm encouraged and discouraged at the same time that this issue runs through many 488 gtbs, pistas and F8's. Go watch the CarWow guy do a video 7 years ago on the 488. He complains about the chirping. Watch Harry's garage review of the 488. You'll hear it chirping in the background. It's there. Some hear it more than others. Consider yourself lucky that Maranello spared you this Ferrari quirk! I'm gonna try the axle nut and see what happens...
    mdrums likes this.
  7. mdrums
    mdrums F1 Rookie
    3,745
    Tampa FL
    Dang.... I hate to hear this. My 488 squealed too but washing the brakes stopped it for around 500 miles of street use. I didn't have the chirp when turning or coasting though. That leads me to believe the pre-fill was causing the pads to ever so slightly touch the rotors for what ever reason.
  8. Mk23
    Mk23 Karting
    Jul 20, 2025
    78
    See that’s what I thought too but what doesn’t make sense is that even on light acceleration especially when you’re coming down a hill, with your foot in the gas, you’ll hear the chirp as well. My understanding is the pre-fill works when you take your foot off the gas, no while it’s on. I’m at my wits end. Let’s see if my mechanic has any insight. I’ll keep you all posted.
    mdrums likes this.
  9. Mk23
    Mk23 Karting
    Jul 20, 2025
    78
    So I wanted to follow up with this issue. So often on this and other car forums, questions come up, people offer solutions, and no one ever follows up.
    Anyway, I took my 2017 488 gtb to my indy guy. Had him order the rear axle nut as another commenter had suggested would solve the issue. We took the car for a test drive prior and he definitely heard the chirp and he also thought it was coming from the left rear. He threw the car on the lift and spun each wheel. Nothing from the rear. Checked the play of the wheels in front of me. No play on the wheel with any motion or force he applied. Ruled out the bad axel nut and possible wheel bearing. However, even on light spinning of the front wheels, in particular, the drivers side, a faint chirp/squeak could be heard. Just for good measure he even accelerated the car on the lift to spin the back wheels to confirm it wasn't coming from there, and no chirp.
    He then took of a very slight amount (less than 1mm) off each pad in the front wheels. Took it home an no chirp! I was elated. Multiple drives no chirp!...until, after 30 miles or so, the chirp returned :mad:! To be fair, it's much more quiet now, however, it's definitely still there. Just as before, only after the car is warmed up well and on coasting. Again, less volume than before, at least.
    Something tells me over time, it'll likely come back to full volume. He then suggested I do some hard braking to try and bed the pads since they were shaved down a bit and have a "fresh" face. I'm gonna try that when I get a chance over the next few days and will report if that solves the problem. Sounds like the noise is definitely brake pad related though. It's amazing how close the pads are to the rotors when the car in neutral or drive. Can definitly understand why many say it's pebbles or grime, etc. What I don't get is why it affects some cars and not others. Perhaps moving to a different pad down the line may be the answer. Thanks all for your insight and help.
  10. richi127
    richi127 Rookie
    Mar 9, 2021
    32
    r
    here’s a sound clip, more pronounced under acceleration. Anyone else experience the same? I am thinking it might be the wheelnuts also (my Porsche had something similar and it went away after they cleaned/lubed the centerlock.
  11. Mk23
    Mk23 Karting
    Jul 20, 2025
    78
    I have the exact same problem that didn’t go away entirely with chamfering the brake pads.
  12. mdrums
    mdrums F1 Rookie
    3,745
    Tampa FL
    I'm listen through 2 JBL 305 powered studio monitors and all I hear is the car engine noise
  13. mdrums
    mdrums F1 Rookie
    3,745
    Tampa FL
    @Mk23 your car has brake pre-fill. Brake pre-fill is an automated safety feature that increases brake system pressure to make braking more responsive. It works by having the vehicle's Electronic Stability Control (ESC) system detect an abrupt lift of the accelerator and automatically move the brake pads closer to the discs before the driver applies the brakes. This shortens the time it takes for the brakes to engage, leading to quicker stopping distances.
  14. Mk23
    Mk23 Karting
    Jul 20, 2025
    78
    There is a high-pitched chirping. It’s a higher frequency so if your ears have been dulled by age/listening to high volume music, you may not hear it, but it’s definitely there. Don’t mean that in a disrespectful way simply saying it’s definitely there and I can hear it on my iPhone even.
  15. Mk23
    Mk23 Karting
    Jul 20, 2025
    78
    Thank you and yes, I’m aware of that system and that has been stated as a potential cause of this issue. Only thing is that first of all not everyone has this issue to begin with and secondly, this chirping sound, while yes it occurs on coasting, can also be heard at times during acceleration until you get past 2800 RPM. But that’s what your foot on the gas. Anyway, at this point, I’ve just chalked it up to something I’ll just have to live with as it seems, others, have it and have concluded the same
    mdrums likes this.
  16. mdrums
    mdrums F1 Rookie
    3,745
    Tampa FL
    My 2019 488 brakes squeaked and howled. I'd clean them and the rotors when I washed the car and it would be fine for around 200 miles and it was back. I did a track day, only 2 sessions and the brake cleaned up some and I wore. lot away and on the ride home the squeal and howling came back.
    I scared to jinx it but at 3200 miles on my F8 the brakes are quite oddly..... hummm
    Mk23 likes this.
  17. Mk23
    Mk23 Karting
    Jul 20, 2025
    78
    Look, I would be ecstatic with cleaning the rotors and pads, which I do every time I wash the car to the best of my ability, to get 200 miles of chirp free driving ha ha. But even after my mechanic shaved off a little bit from the pads, I got maybe 20 miles of chirp free motoring. Like I said, I think it’s just something I’ll have to accept with my car.
  18. richi127
    richi127 Rookie
    Mar 9, 2021
    32
    r
    took mine to track day and the chirping became worse on the drive home. I think it has to do with the carbon ceramic brakes or pads likely expanding under heat. The car does not have those chirping noises when cold. A mechanic advised to clean and remove residue via chemical/physical means, rotors and pads. I'll see how that goes.
    Mk23 likes this.
  19. Mk23
    Mk23 Karting
    Jul 20, 2025
    78
    Good luck. Mine went away briefly after the dealer cleaned the pads and rotors. Then went away longer after my new mechanic shaved a small portion off the front pads, but came back. There now but less intense than before. And yes you're right, only comes on after the car is warmed up. Has to be something like you said with the braking system warming up. You would think at the track, with all the hard braking, you'd "clean" the pads. Let us know how it goes.
