Pista or Refresh | FerrariChat
Pista or Refresh
Discussion in '458 Italia/488/F8' started by doccharlie954, Feb 28, 2019.
  1. doccharlie954
    doccharlie954 Formula Junior
    Jul 27, 2010
    256
    Brother in law has a spot for the Pista. Here's the dilemma, should he stick with the Pista or order the refresh and bow out on the Pista . Thanks
  2. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    13,892
    Robb
    Pista should always be worth more...
    Robb
    09Scuderia likes this.
  3. willcrook
    willcrook Formula 3
    Feb 3, 2009
    2,141
    depends, pista will hold its value better f8 will be similar to drive but more sedate and will take longer before he gets a physical car (most likely)
  4. ttforcefed
    ttforcefed F1 World Champ
    18,875
    avoid both, buy a CS, and reassess in 24 mos
  5. SoCal to az
    SoCal to az F1 World Champ
    14,224
    Arizona
    F8 I think is going to get destroyed long term if value is what you re looking for. I think Pista is unique and will do much better long term. But as tt said, Id wait for the actual replacement and buy something else.
  6. dmark1
    dmark1 F1 World Champ
    BANNED Owner
    Feb 26, 2008
    11,439
    Americas Team Headquarters
    Mark
    Pista without a doubt. Rarer, more special, prettier and faster I bet.
    Which should you have bought in retrospect in 2004, a Challenge Stradale or a 430 coupe?
    I rest my case.
  7. ttforcefed
    18,875
    how many f8s will be made?
  8. ItalianOne
    ItalianOne Formula Junior
    May 21, 2008
    614
    Mich
    Kevin R
    I am hearing that there are no more tours of the V8 line cause the F8 are starting production. Also that the pista is going to more limited then people thought initially since Ferrari is introducing a few new models in the coming years. Is there any truith to this?? As mark says I think the Pista is going to be rarer, more special and prettier and faster.
  9. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,291
    I think the price difference between the F8 and Pista is a knowable factor.
    Production numbers for each car is less transparent.
    How many years will the Pista run vs the F8?
    And then how will the upmarket V8 hybrid affect the value of the Pista. The Pistas claim to fame is its performance. When that is eclipsed, which I’ll wager will happen with the new hybrid V8 turbo, the value of the Pista will soften.
  10. obbob
    obbob Formula Junior
    Aug 14, 2017
    774
    My rule: If the choice between an older hardcore version and a newer regular version, always go hardcore!
    Doesn’t just apply to Ferrari. Huracan Performante over Huracan Evo, 675LT over 720S, and Pista over F8.
  11. markcs
    markcs Karting
    Oct 23, 2016
    141
    100%
  12. Steph355au
    Steph355au Rookie
    Oct 31, 2003
    31
    From what's been said the V8 hybrid will sit at the top of the Ferrari range well above the Pista price. If anything it might make the Pista look like good value.
    If it was me I’d stick with the Pista. It’s the last chapter in a series of special edition V8s stretching back to the CS and as such will always command a premium.
  13. daflk
    daflk Formula Junior
    Jan 27, 2013
    257
    Hong Kong
    The engine is not the same. Despite similar stats. Look at the RPMs needed to achieve peak torque. Pista is challenge engine F8 is a modified 488. If that helps.
  14. Ferrari 308 GTB
    Ferrari 308 GTB F1 Veteran
    Feb 21, 2015
    7,745
    Tropical
    Pista has 50% of the base 488 engine.It has Turbos and exhaust plus other items from the Challenge engine.Don't know exact details of F8 so far.
    Igor Ound likes this.
  15. [gTr]
    [gTr] Formula 3
    Mar 11, 2008
    1,024
    Hamburg, Germany
    Here is an alternative POV.
    This car only has a 2 year run, the same as a Pista. All the people that buy the latest greatest already got Pistas and it will still be a new car for most of the production run of the F8 and for the rest it would make more financial sense to wait for the all new V6 hybrid. There might just be less demand for the F8 than anticipated and maybe after all is said and done there might be less F8s produced than Pistas!
    theplanner likes this.
  16. Ferrari 308 GTB
    Feb 21, 2015
    7,745
    Tropical
    You may well be right. They talking around 4700 Pista/Pista Spider plus they are still cranking out the Portofino and the V12's .Total production is what +/- 10000 pa?
  17. Silberpfeil
    Silberpfeil Karting
    Jan 2, 2016
    96
    Lucerne, Switzerland
    Marc Brunner
    Little bit less than 10000. it was 8400 in 2017 that increased in 2018 by a few percent.
    Gesendet von iPad mit FerrariChat
  18. Silberpfeil
    Silberpfeil Karting
    Jan 2, 2016
    96
    Marc Brunner
    And they are selling Portofinos like Croissants right now.
    Jelial likes this.
  19. iloveferrari
    iloveferrari Formula 3
    1,853
    Just be careful of the word last here
    sampelligrino and SoCal to az like this.
  20. JackCongo
    JackCongo Formula Junior
    781
    Jacques
    So true, nothing to argue...
  21. Ferrari 308 GTB
    Feb 21, 2015
    7,745
    Tropical
    Yes but dont forget production numbers...CS 1200 Pista 4700 ish?
  22. dmark1
    BANNED Owner
    Feb 26, 2008
    11,439
    Mark
    Wrong. According to my dealer (largest in the nation) the Pista engine is 90% challenge engine. According to several Challenge drivers it is the most “challenge like” car they have street driven ....much more so than either the Speciale or Scuderia were.
  23. dmark1
    BANNED Owner
    Feb 26, 2008
    11,439
    Mark
    Ummm , who exactly is “they’re”? That’s the biggest load of ********* I’ve ever read.
    My dealer (again, by volume at his two seperate F dealerships) is the largest in the nation. His “best guess” based on allocations is 2500 TOPS. And 40% tops make North America. Less than Speciale because of a smaller calendar time allotted to their run.
    But go ahead.... believe “They’re” whoever “They’re” (read- your imagination) is.
  24. Ferrari 308 GTB
    Feb 21, 2015
    7,745
    Tropical
    No doubt your dealer is better informed than i am ,no doubt its a monster engine.
    dmark1 likes this.
  25. dmark1
    BANNED Owner
    Feb 26, 2008
    11,439
    Mark
    My bet it’s pretty close to the same engine without the titanium connecting rods and iconel exhaust to save a bit of money.
    I predict the new car will sell right at 400k optioned putting it squarely between thev488 and the Pista.
    nads likes this.
