Pista wheels, will the 488 wheels fit on a pista ??? | FerrariChat
Discussion in '458 Italia/488/F8' started by RobertM, Jan 3, 2019.
  1. RobertM
    RobertM Formula 3
    Apr 17, 2005
    2,420
    Weston, Florida
    Robert M
    I have a 2018 Ferrari 488 gtb and installed vossen HC-1 and are 20 - 21 and wanted to know if anyone knows if they will fit on a Pista. Not sure if the brakes are larger that the 488gtb. wheels are 20x9 (offset +35) and 21x12 (offset +35)
  2. LVP488
    LVP488 F1 Rookie
    Jan 21, 2017
    4,870
    France
    Apparently tyres dimensions are exactly the same for the GTB and Pista so wheels are the same sizes - but I do not know about the offsets. It seems that the rear and front tracks are also the same though, so it's likely to be identical.
    Standard wheels are all 20" though.
  3. markcs
    markcs Karting
    Oct 23, 2016
    141
    There are a few Pista photos on this forum with gtb wheels
    So I would say yes
    458-Italia likes this.
  4. 458-Italia
    458-Italia Formula 3
    Jan 10, 2014
    1,726
    France
    I agree
  5. obbob
    obbob Formula Junior
    Aug 14, 2017
    774
    Speciale and Italia wheels had different offsets. However, I think the actual fender and mounting point was the same, so an aftermarket wheel could fit both cars the same.
    I would confirm with a wheel dealer however.
  6. MuratC
    MuratC Formula Junior
    Jul 6, 2014
    539
    Istanbul, Turkey
    OK how about Speciale wheels to Pista?
  7. LVP488
    LVP488 F1 Rookie
    Jan 21, 2017
    4,870
    France
    offsets are different between the Speciale and 488 GTB, so if Pista is like the GTB there will be the same difference.
  8. Netpark
    Netpark Rookie
    40
    If offsets are different, can I add spacers to Pista wheels to fit on Speciale? I have an extra set of wheels from my Pista since the carbon wheels were delayed by several months. I’d like to add those 10 spoke wheels to my Speciale. Wheels are sitting at the Ferrari service dept.
    Thanks in advance.
  9. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    Okay let's clean all of this up a bit. No guessing.
    The 488 and Pista has the same offset. Also, they share the EXACT same brakes. Same disc, same pads, caliper, same master cylinder, same lines. Everything is the same. If it fits on a 488 it will fit on a Pista.
    Now as far as the Speciale goes. It has 10 mm more offset than a Pista/488/F8 in the rear. A Pista has 38.5mm of offset and the Speciale has 48.5. A Speciale has about 20mm of outside clearance between tyre and arch. A 12" wide rear wheel with an offset of 35 on a Speciale will poke way out of the fender as the outer fender lip will be moved 26mm out compared to stock. If you are running 325(30R21 tyres, they will sit about 24 mm further out compared to stock. Those rear offsets are no-go on a Speciale.
    IanD1, Gh21631, Netpark and 1 other person like this.
  10. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    No you cannot. You can add spacers to Speciale wheels to fit them on a Pista. That being said, if you stick to stock size, your Pista wheels will fit find on the Speciale. The fronts have the same offsets and there's room enough in the rear to clear the 10mm the Pista wheels will sit further out compared to the Speciale wheels. But you should consider installing 10mm spacers in the front if going this route. It will not only look better, it will also combat some of the understeer you get from adding track width in the rear. If you install 10mm spacers in the front, you have widened the track 10mm both front and rear.
    Netpark and 350MH83 like this.
  11. Netpark
    Netpark Rookie
    40
    Excellent explanation. Really appreciate your knowledge.
    Do you think this will effect drivability and handling at all?
    Are there any spacer brands you recommend?
    And finally, will this in any way void my CPO warranty?
    Again, thank you so much!
  12. rumen1
    rumen1 Formula 3
    Jun 23, 2012
    1,695
    Bulgaria
    Adding spacers to such a car is never a good idea, on my opinion...
  13. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Staying with conservative changes is not a big deal, but yes, it will affect handing. The car will feel a bit softer as you move the loading point of the suspension away from the pivot point. as you increase track. The reason why I think it's a good idea to add spacers in the front, is because the added track in the rear by itself will increase understeer, and lord knows understeer is the last thing these cars need more of. But to be fair, if you go with a conservative spacer and don't track the car, I doubt you will notice much of a difference.
    As far as safety goes, I'm a huge proponent of not doing the wrong thing the wrong way. When it comes to spacers for Ferrari, there's really only one manufacture I trust, and that's Hill Engineering. Use their 11mm spacers in the front and get them with a matched set of bolts. You can get bolts in both steel and titanium, and no matter which one you choose, they are of superior quality to what's on the car. If you do the install of the spacers yourself, use wheelhangers. Those help ensure everything stays properly centered and can get properly tightened. The Hill spacers have steel inserts in the holes which both prevent them form deforming during driving, but also due to clamping forces and heat. Can spacers be run safely? Yes, but it needs to be done right. Lastly make sure your get your car checked for alignment. When you add spacers anywhere the alignment is off could be amplified by the spacer in some cases. For example if a wheel have had a bit of a scuff with a curb. It might not be visible on the wheel itself and the tyre might have taken the hit, but if a wheel is toed out say 3.5-4 degrees instead of stock alignment, the added front track can really make the car handle funny in such a situation.
    Never heard of spacers messing with the warranty. Thousands of Ferraris run spacers and I've yet to hear of an issue.
    Netpark likes this.
  14. mathewr
    mathewr F1 Rookie
    Sponsor Rossa Subscribed
    Dec 7, 2011
    2,803
    Deep in the Heart of Texas
    Ferrari Wheel Guru
    Just to be clear the 488/488 Pista/488 Pista Spider wheels will work on the 458. I have been asked this question three time this week randomly as I have a set of Pista Spyder wheels for sale. Below is what I have found.
  15. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    That was also what I said. To be real clear, it is worth noting that those rear wheels are at the limit on a normal 458. With a change in offset of 20mm and wider wheels, some will experience a slight rubbing during hard compression. This is also the case when running 20mm spacers on stock 10.5 inch wide wheels. Going out 20mm but also increasing the rim to 11 inches, will.increase the chance of rubbing.
    It is also worth noting that moving the tyres out this much greatly increases how much of a beating the paintwork takes. This is something many installers of aftermarket wheels "forget" to inform the client about. But a set of 488 wheels on a 458 will throw tons of road grit up the side as the fenders no longer covers as well. Just something to be aware of. Lastly the added 40mm track will add substantial understeer. To be as clear as glass. Can 488 wheels be used on an Italia or Spider? Sure. Are they a really good fit? Only for those who seek the flush look at don't worry about how well the car works as an actual performance car.
    Netpark and LVP488 like this.
