piston rod | FerrariChat
piston rod
Discussion in 'Other Off Topic Forum' started by Auraraptor, Dec 7, 2003.
  1. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,958
    MO
    Omar
    can someone tell me what a piston rod is and how it works. I think it is the rod that connects the piston to the crank shaft, but i'm not sure.
  2. F40
    F40 F1 Rookie
    Apr 16, 2003
    3,230
    AZ
    The connection rod connects the piston to the crankshaft.
  3. Auraraptor
    Sep 25, 2002
    13,958
    MO
    Omar
    then what is the piston rod?
  4. EspritSE
    EspritSE Formula Junior
    Dec 1, 2003
    509
    Colorado
    Craig
    Piston rod is a 'Grassroots' term for connecting rod. Connects piston to crankshaft. Wrist pin connects piston to connecting rod. Length of connecting rod (way simplified, no flames please) determines an engine's stroke.
  5. Steve Magnusson
    26,772
    Are you dealing with a translation? I'd also guess "piston rod" = "connecting rod", but I could see how "piston pin" (a.k.a. wrist pin, Gudgeon pin) could also come out "piston rod" if passed around thru enough Italino-English (British)-English (USA) translations.
    Can you use the phrase in a sentence? ;)
  6. F40
    F40 F1 Rookie
    Apr 16, 2003
    3,230
    AZ
    Piston pin is also used as wrist pin.
  7. EspritSE
    Dec 1, 2003
    509
    Colorado
    Craig
    #7 EspritSE, Dec 7, 2003
  8. Auraraptor
    Sep 25, 2002
    13,958
    MO
    Omar
    thanks for the info. I was also wondering how much stress is applied to the connecting rod and I was wondering what the maximum temperatue a combustion chamber recieves. Any info on this will be greatly appreciated.
  9. F40
    F40 F1 Rookie
    Apr 16, 2003
    3,230
    AZ
    stress... going up at a high rate of speed, suddenly stopping, going back down, 25-75 times a SECOND!
  10. beast
    beast F1 World Champ
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    TEmperatures inside of a combustion chamber can peak above 2200 degrees F for a few milliseconds each combustion cycle.
    As for connecting rod stress there is a lot of variables that have to be factored in to come up with an accurate #
    Rod length
    Rod Design
    Crank Stroke
    Compression Ratio
    Ignition Timing
    are just a few of the variables that affect conn rod stress.
    Rob Guess "The Other Rob"
  11. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,721
    Forgot the most important:
    Maximum RPMs
    Piston weight
