placement of scuderia badge on 360 | FerrariChat
Discussion in '360/430' started by djastral69, Jul 20, 2009.
  1. djastral69
    djastral69 Formula 3
    1,896
    Fl
    David
    I have a set of the metal Scuderia badges(adhesive backing) to put on my 360 and would like to know if anyone can please help me with the proper placement. Thanks ;-)
  2. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    If you search for that you'll find it.
    It was done more than a few times here.
  3. djastral69
    1,896
    Fl
    David
    I did a search before posting but couldn' t find anything?
  4. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    #4 GCalo, Jul 20, 2009
  5. djastral69
    1,896
    Fl
    David
    Thanks but no dice. Anyone else...Bueller, Bueller...need the proper placement instructions please
  6. F1dreamer
    F1dreamer Karting
    Nov 10, 2008
    232
    Atlanta
    You could try to put it on upside down. Kinda like that stamp that has the airplane upside down, the only one ever printed. You could tell people that it came from the factory that way, would automatically be worth millions......
    JRice360$pider likes this.
  7. djastral69
    1,896
    Fl
    David
    Yeah, that's funny Dreamer!!! Kinda like living in Atlanta and dealing with Freaknic every year Huh....
  8. jjsaustin
    jjsaustin Formula Junior
    May 11, 2008
    579
    Austin, TX
    Jim
    Where did you get your badges from?
    This may be helpful
    http://yoshield.com/index.asp?PageAction=Custom&ID=3
    -Jiim
  9. paulie_b
    paulie_b F1 Veteran
    Jan 13, 2003
    6,842
    Jupiter, FL
    Paul Bianco
    David, here you go:
    When looking at the driver side, the top right corner of the shield is 72mm from the door (excluding door gap). The bottom edge of the shield is 84mm from the door (again, excluding door gap). Reverse all measurements for a passenger side.
    Hope this helps.
  10. djastral69
    1,896
    Fl
    David
    Thank you Paulie, I'm on it. By the way JJ's I'm using the badge from Scuderia in the UK. 1mm thick ones, I've read good things about them. I'm not one to add too many nonfactory things to a car but I previously had a 360 spider and it had the badges and well, I like them ;-).
  11. F1dreamer
    F1dreamer Karting
    Nov 10, 2008
    232
    Atlanta
    Yeah, they don't do freaknic here anymore, guess they though people screwing on cars in the middle of traffic was bad for tourism.
  12. djastral69
    1,896
    Fl
    David
    #12 djastral69, Jul 21, 2009
    Dreamer, You don't even own an F~Car so why are you posting negative comments? This board was put here for others to help one another not be negative(like you). I'm sure that everyone else on F~Chat would agree. Please post helpful comments or just Go Away as we wold all appreciate it!
  13. F1dreamer
    F1dreamer Karting
    Nov 10, 2008
    232
    Atlanta
    Man you took that as a negative comment? You have such a fragile ego dude.
  14. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,179
    Wash DC area
    Robert
    Here are some measurements for you, sorry they are late, hope they help!
    On the drivers side, the top right corner of the shield should be 72mm from door panel gap, and the bottom 'tip' of the shield should be 84mm from the door panel gap. Using those two measurements should, based on the curvature of the fender, provide the correct vertical orientation as well as horizontal.
  15. djastral69
    1,896
    Fl
    David
    Thanks guys I really appreciate your help.
  16. djastral69
    1,896
    Fl
    David
    ok, I used these measurements and you can have these distances at many points on the fender. Is there something a little more specific on the measurements such as distance from the line in the fender so that I can judge the placement fron top to bottom? Thanks
  17. Lefteris
    Lefteris Karting
    Apr 2, 2009
    77
    Athens, Greece
    Lefteris
    Please post photos when you put them on!
  18. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,179
    Wash DC area
    Robert
    #18 E60 M5, Jul 30, 2009
    Here are some pics of after the install my wife did on the 360. She used the measurements I gave above and placed two lines of masking tape, top and bottom, level of course and then applied the shields. She took a quick reference from a 360 with factory shields for placement on the fender. I don't think you can go wrong as long as you are on the curvature of the fender out from the door according to the measurements.
    Maybe the pics will help a little.
  19. djastral69
    1,896
    Fl
    David
    #19 djastral69, Jul 30, 2009
    Thank you Very much Robert. Would you say that the point at the bottom of the shield is an inch off(above) the crease or line of the fender? Also, how did you go about bending the shield for the right curviture and perfect fit? Thanks Again...
  20. kouroshoo7
    kouroshoo7 Formula 3
    Jul 21, 2007
    1,088
    Kourosh
    why even have them...they always are not meant to be there..... there is already a badge on the hood..... im sure people will know its a ferrari with out the shield...trust me
  21. djastral69
    1,896
    Fl
    David
    Just like the look of the shields and don't really care about what others think, it's my preference Kourosh that's all....
    brookliner7 likes this.
  22. Dean Lewis
    Dean Lewis Formula Junior
    May 16, 2009
    449
    QLD, Australia
    Dean Lewis
    where did u buy the badges from?
  23. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,179
    Wash DC area
    Robert
    Well for starters they could have been installed as this was an option at purchase. Second, why make any mod to a car, because its my car and thats the way I wanted it to look. Lastly, most people don't know its a Ferrari they usually thinks its something else and who cares what people think the cars are.
    The shield is a part of the racing heritage of Ferrari and I for one think it should be on all the cars. Its a direct link to the "scuderia" known as Ferrari.
    Anthony 360 F1 and brookliner7 like this.
  24. djastral69
    1,896
    Fl
    David
    Hey guys, still looking for anyone to measure the bottom of their Scuderia Badge to the crease on the fender just below it for placement purposes. It looks to be just between .5 to 1". Please confirm, Thanks
