Plastic parts slightly off in color... | FerrariChat
Discussion in '360/430' started by johan6504, Jan 7, 2012.
  1. johan6504
    johan6504 Formula 3
    Jun 28, 2005
    1,168
    Sweden
    Johan
    As a new owner of a 430 Scuderia (Rosso Corsa 322 PPG) I am wondering if anyone else has noticed that the plastic parts is slightly off in color. I guess I am more sensitive to color differences than most people and in artificial light, like halogen light I get the feeling that the plastic parts is slightly more red than the rest of the body, that looks a bit more orange...
    The whole car looks the same (front rear and rocker panels) and from what I know the car has never had a respray, except maybe for the front. In daylight/sunlight I don't see the same difference so it isn't a big problem but I am a little curious if anyone has noticed the same.
  2. m.roberts
    m.roberts Formula Junior
    Nov 2, 2009
    907
    John,
    Can u be more specific as to where you notice differences?
    For example... My new scud, the front bumper IMO is brighter or darker red than the front hood/fender of the car.
    My car was a 1600 mile car when I bought it and is confirmed as having zero paint work or sprays... Yet in good artificial light, I can see an obvious difference... Why it is different, that I cannot explain and frankly, being as picky as I am, it makes me crazy!
    Btw, mine is rosso corsa 322 also
  3. johan6504
    johan6504 Formula 3
    Jun 28, 2005
    1,168
    Sweden
    Johan
    Hi
    All parts in plastic, rocker panels, front and rear bumper seems slightly brighter or more orange than the rest of the car.
  4. Mikkofin
    Mikkofin Formula Junior
    Jun 30, 2011
    291
    Finland
    Even with a 360 with the same color, its exactly the same thing. My 360 has had nothing painted on it since new.
  5. johan6504
    johan6504 Formula 3
    Jun 28, 2005
    1,168
    Sweden
    Johan
    OK, sounds like it is pretty normal then...
  6. Russell996
    Russell996 Formula 3
    Sep 24, 2010
    2,263
    New Forest UK
    Russell
    Not a problem I've seen on either my Rosso Corsa 430 coupe or on my 16M with 3 layer. Paint is a perfect match across all panels. Both cars needed detailing to remove paint imperfections/sanding marks as per usual Ferrari finish but no colour problems - sorry.
  7. Monza 456
    Monza 456 Karting
    Sep 15, 2005
    231
    Portland, Oregon
    Craig Nelson
    90% of the Ferraris I see or deal with have a small difference in the bumpers and rockers. This is normal. Usually the ones that match the best are cars that have a complete repaint or special ordered colors, those cars are pulled off line and painted at a different facility, not at the factory.
  8. mags355
    mags355 Karting
    Oct 29, 2007
    70
    maged
    Could also be that the paint on plastic and on the metal have a difference in shade,
    Once the paint is adhered to the surface. the paint on the plastic might give a deeper
    look than on the metal body.
  9. johan6504
    johan6504 Formula 3
    Jun 28, 2005
    1,168
    Sweden
    Johan
    Got a mail from the previous owner and he can confirm that no respray has been done on the car, guess this is normal then.The 355's I used to own never had this problem, but then again they were all hand painted if I am not mistaken, with their own little paint imperfections...
  10. Tonym3
    Tonym3 Rookie
    Dec 21, 2011
    8
    Spot on. I have sold new cars for around ten years and although it's a very small difference there is always a slight difference between how plastic and metal show the paint.
    I notice it more on silver and dark blues. We have had a few people complain that the new car must have had a respray over the years.
  11. zackspeed
    zackspeed Karting
    Nov 4, 2003
    67
    AZ
    Zack
    That's how you know it's factory original!
  12. Kouki Monster
    Kouki Monster Formula Junior
    Feb 26, 2007
    422
    Washington
    AJ
    sometimes it has a lot to do with what sealer/primer is used before the paint is laid down. When i paint cars and or have to repaint a bumper to match. I find out what sealer color is on every panel before paint is applied to match oem body color. Red paint you want to use a red sealer to minimize shade and tone issues. If you use gray which a lot of people do, and your layers of paint are different you will get the effect you are talking about. Since it take more red to cover gray sealer than red sealer.
    This also happens with metallic as well! if a bumper is not sprayed the same way the body is longitudinally sprayed the metallic will flop and cause a contrast. You can not blend with metallic well, and I advise against it! There is a lot of repair jobs where silver in certain light looks darker or cloudy cause it was sprayed on top of the clear to give a blend into an adjacent panel. Causing a prism effect. Which you are essentially spraying metallic over a gap between metallic paint. Which is why, real shops, only spray the whole side of the car, not just a fender into door. And! if you have a insurance claim cause of it, please, spend the extra to have the whole side, or car done depending on accident. Silvers yellow out so any new paint you apply will look a lot more crisp. Where as Reds tend to pink, or orange out depending.
    Also, the plastics used may heat up differently than aluminum (this is theory) but it might heighten the aging process of which paint discolors at.
  13. Mikkofin
    Jun 30, 2011
    291
    Finland
    Audis are notorious for this. Look up for example a white A4 from a parking lot.
    The bumper color is WAY off from the body color. More grey / not as bright white.
  14. johan6504
    johan6504 Formula 3
    Jun 28, 2005
    1,168
    Sweden
    Johan
    Really liked that comment :)
    It sounds like this is a fairly common problem then, and I do understand the reason why it happens. It somehow feels like a typical Ferrari problem though... If this would have been a paint job I have ordered separately I probably would have had the paint shop correct it.
    The good thing is that I feels better now when I know I am not alone :)
