Plastic repair | FerrariChat
Plastic repair
Discussion in '348/355' started by dahveedem, Jan 30, 2013.
  1. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    #1 dahveedem, Jan 30, 2013
    So I had posted a few months ago about doing some plastic repairs and hadn't found anything to do it well.
    I ran across this site (no affiliation) plastex.net.
    Ordered some of the black repair kit.
    One of my side corner panels has the hole all stripped out. I used the repair kit tonight on it. This is while it's drying. Will post more after I sand it, drill it and paint it.
    Even right now after about an hour dry time it's pretty hard.
    Was curious if anyone has used this or something similar?
  2. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Best bet is identify the plastic and use the correct repair compound. SEM makes some easy to use stuff you can get them at an autobody supply house.
    looky here
    SEM Adhesives, Sealers and Repair Products
    Wurth makes great stuff also but hard to get unless the salesman come to your shop
  3. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Expensive Ferrari plastic... That is the best id I got for you.:D.
    Mobilized reply by David
  4. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    You can glue it just make sure you use a "hard" plastics glue - otherwise it wont work! Ive repaired my window trauangles, vents, ashtray etc lik ethis and theyve all lasted :)
