Please Confirm Correct 328 Undercarriage Battery Bay? | FerrariChat
Discussion in '308/328' started by pj57, Dec 8, 2019.
  1. pj57
    pj57 Karting
    98
    Austin, TX
    I’m unfamiliar with 328s, so I’ll defer to the experts. Car pictured is a low-mileage ‘89 328 GTS that I looked at with a friend who is looking to buy. He will PPI with a Ferrari indy if things get serious. My main question is whether or not the battery bay is uncovered as the photo reveals or is there a cover missing? Everything looks original and all screws are in place, so my thought is this is correct. Just seems odd to have battery exposed to elements. PJ
  2. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    There's a cover that's missing.
    Matto likes this.
  3. pj57
    pj57 Karting
    98
    Austin, TX
    Anyone have a pic of the cover installed? Thanks
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,551
    San Carlos, CA
    Mitchell Le
    Nothing is missing in that picture for an 89. In fact the slotted vents plate seems to be missing on my car.
  5. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    The 89 is simply exposed on the underside like that? I find that baffling, considering earlier models aren't. Road debris would be a hazard to the battery.
    Matto likes this.
  6. pj57
    pj57 Karting
    98
    Austin, TX
    #7 pj57, Dec 8, 2019
    Above are photos supplied by a dealership showing the underside of three different 328s (first two photos and last two photos are of same car). Unless all had intentionally removed the battery cover, it would appear Yelcab is correct - there is no cover! The anomaly is the very first photo of the post that shows a presumably factory installed louvered panel where none of the others have it. Didn’t think I’d be starting a research project, FYI, I recall that the ‘89 GTS I was looking at was February, 1989 production.
    Rifledriver likes this.
  7. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,808
    Cerritos, CA.
    If it doesn’t have a cover originally, I’m pretty sure it can be easily make one if need to.
  8. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    Mine has no louver and that one looks suspiciously like a Lowes vent bent just so.
    thorn likes this.
  9. JV's89
    JV's89 F1 Veteran
    7,292
    Pittsburgh, PA
    My '89 has the louver too.
  10. yelcab
    Nov 29, 2001
    13,551
    San Carlos, CA
    Mitchell Le
    62492500 GRILL , unsured if that is used on all models or not. Can easily be made with a Home Depot screen. I think it is there just to protect the ABS pump located right above it. I don't have one, and unlikely to spend $100 for one.
  11. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    So... my 308GTSi (1982) has a solid aluminum panel. Is there a benefit to having more air flow exiting under the car?
  12. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    Probably, if it goes under the car there is less heat to go over the car into the cabin. I still plan on fabricating a flat or louvered panel (Can you say A/C intake from Lowers?) to help pull some hot air out. of course I plan on finishing some body work on the E-Type too so don't hold your breath for pics.
  13. Freddie328
    Freddie328 Formula Junior
    Jul 29, 2013
    389
    Herts, UK
    Richard
    Interesting. The battery was exposed on mine, but had the grille. Dealer I bought it from said there was a missing plate and made one from aluminium. That was sixteen years ago. Never had an overheating problem.
  14. Rifledriver
    37,089
    Hes wrong. No cover.
  15. Rifledriver
    37,089
    The louvered panel goes under the ABS unit. Supposed to be there.
  16. Rifledriver
    37,089
    They are all like that
  17. Rifledriver
    37,089
    Does your car have ABS?
  18. Rifledriver
    37,089
    Not supposed to. The cover is under the steering rack and water pipes.
  19. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    How odd...well, today was a learning day. Apologies to the OP for causing unnecessary concern.
    pj57 likes this.
  20. Rifledriver
    37,089
    That is where most of the air from the radiator exits. None of the 308/328 had that covered.
  21. Rifledriver
    37,089
    You came here to ask the experts. Boy did you come to the wrong place.
    BigTex and Saabguy like this.
  22. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Mine (85) doesn't have a large hole behind the front spoiler; it's all covered underneath. Is is a US vs Euro difference, or some other factor?
  23. pj57
    pj57 Karting
    98
    Austin, TX
    Yelcab had the answer right away. The only remaining issue was the louvered panel which so far looks like an ABS model only part.
  24. Rifledriver
    37,089
    Show us a picture.
    Thats where radiator air gets out.
