Please Confirm Correct 328 Undercarriage Battery Bay? | Page 2 | FerrariChat
Discussion in '308/328' started by pj57, Dec 8, 2019.
  1. Rifledriver
    34,133
    Austin TX
    Sure didn't stop the wrong answers.
  2. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
  3. BigTex
    79,218
    Houston, Texas
    Bubba
    The early 308s had the under body of the front valence all the way beneath the battery.
    With an oval cut out to reach a frame mounted tow point, and a tube to vent the battery, back when they were built with one.
    I rusted out a three piece steel one, and the glass ones were solid, in the area open on a 328
    But Rifledriver is putting forth a good point, the front radiator air flow is greatly improved to dump it below the car.
    This is a change from our early cars, which had an air deflector below the engine, seeking cool air to pump UP thru the rear hatch!
  4. Freddie328
    Freddie328 Formula Junior
    Jul 29, 2013
    294
    Herts, UK
    Richard
    Makes sense. At the moment mine goes all out through the louvres above the spare wheel. In high humidity when the wind shield is cold, when the fans start the warm air causes the glass to very quickly steam up on the outside. Sending some air down through the bottom should reduce this issue.
    And there was me thinking this was a design issue!!
  5. Albert-LP
    Albert-LP F1 Veteran
    7,784
    around Modena, Italy
    Alberto Mantovani
    #30 Albert-LP, Dec 14, 2019
    Euro 328 GTS, 1986, chassis 66731.
    Pictures taken from Classiche redbook: no red lines, means "detail in original Factory conditions".
    Rifledriver (Brian Crall) does know what he is saying.
    Ferrari Copyright
    ciao
  6. Rossocorsa1
    Rossocorsa1 F1 Veteran
    May 14, 2017
    6,203
    Brian Crall (Rifledriver) is absolutely correct. Disregard the other comments.
