Please confirm me with this 360 door lock | FerrariChat
Discussion in '360/430' started by 24000rpm, Mar 2, 2014.
  1. 24000rpm
    24000rpm F1 Rookie
    #1 24000rpm, Mar 2, 2014
    assuming the car isn't locked , is the button always like this? i tried to manually push down the button and it won't do it.
    Today my alarm starts to act up , I lock the door and it beeps 4 times then alarm was set off.
    i thought it has something to do with this
  2. vrsurgeon
    vrsurgeon F1 World Champ
    16,554
    Charleston, SC
    Curt
    Pull up the arm rest (from the rear) and turn the adjuster nut to lengthen the rod. The button will go higher and you'll be able to lock it. 4 beeps means too much tension on the rod from this button so can't lock.
