Please help me diagnose my no start issue. 5.2 F355 | Page 3 | FerrariChat
Discussion in '348/355' started by Rob'Z, Feb 8, 2014.
  1. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    Any updates to this thread? The suspense is killing me.
  2. Barnone 308
    Barnone 308 Formula Junior
    Mar 22, 2004
    432
    canada
    You should try these guys and see what they can do for you as they maybe able to repair you ECU.
    ECU DME Testing Service for BMW Porsche Volvo Jaguar Ferrari Free Shipping | eBay
  3. Barnone 308
    Mar 22, 2004
    432
    canada
    ecudoctors.com
  4. Markphd
    Markphd Formula Junior
    Mar 10, 2012
    713
    I have an ECU for sale
    Sent from my SM-G920P using Tapatalk
  5. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    I would just replace your faulty ecu with a working oem one and be done.
  6. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
  7. Rifledriver
    37,288
    You should probably reverse the fuel supply and return lines at the fuel manifold.
  8. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I like it!!
  9. tbakowsky
    Sep 18, 2002
    20,034
    The Cold North
    Tom
    I had an immobilizer box go bad on me in 550 while it was in for service. Car ran beautifully after the service, parked it outside. Went to bring it in that evening before close..no start. Putted around with it for almost a full week until I pulled an immobilizer from a 355 and pulged it in. Car fired right up.
  10. m.stojanovic
    m.stojanovic F1 Rookie
    3,297
    Serbia - Niš
    Miroljub Stojanovic
    Perhaps you should carefully check all solders of the ECU's male pins to the motherbard. It is possible that one of them is bad and unplugging and plugging the connector moved it a bit establishing temporary contact.
  11. Andy 355
    Andy 355 Formula Junior
    Jun 2, 2013
    434
    We all agree on the alarm battery being the issue with the red light on the dash. I feel for you if you still are unable to drive your pride and joy. Please tell us its all fixed?? If not, one part often overlooked is the ignition switch. I have a fully equipped shop and i have seen the issues a failing ignition switch can cause. Saabs Trionic system plays funny games when the switch fails. I sure hope this helps you. Cheers Andy.
  12. WATSON
    23,903
    WI
    Interesting. I always thought the swapping of those alarm control boxes was more complicated than that. Just a simple swap?
  13. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    It is that easy in a 355 and I guess the 550. Just plug in the different immobilizer and you are good to go.
    The later ones in the 360 paired with the drivers side computer so if you put in a different one you have to swap the ECUs from side to side so the immobilizer has a fresh ECU to pair with.
    Both are easy replacements if you have a good imobilizer with fobs. The whole complication is in the PIN and trying to program fobs... doesn't seems to work as advertised.
  14. Andy 355
    Jun 2, 2013
    434
    Maybe its just me. Whats strange was the cel there one minute and not there the next... No fuel pump, and other strange happenings. Again, a failing ignition switch on a car nearing 20 years old.... I know what id be checking next...
  15. Rob'Z
    Rob'Z Formula 3
    Mar 29, 2008
    1,024
    Tucson,AZ
    Robert
    It was a bad ECU. I installed a known working used ECU and the car now runs again.
    2 years and 3 months later..............
  16. Markphd
    Mar 10, 2012
    713
  17. Markphd
    Mar 10, 2012
    713
    So how was the first drive?
  18. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Glad to hear it's back on the road.
  19. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Did the old ecu just quit?
    I guess if its now fine it must have been a fluke.
  20. ducrob
    ducrob Formula Junior
    Nov 20, 2011
    749
    Canada
    Rob
    Had mine tested and cleaned/repaired at a local avionics shop for $150 CDN...this stuff is ancient technology to them....they literally smelled the bad circuit board before testing it. It was the fuse block in the passenger side footwell. Yeah....not the CDI but just send it (whatever electronic stuff you suspect is defective) to a specialist....they love mocking Italian "exotic" electronics:)
  21. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    So you had your fuse block fixed not the ecu?
    If it was the ecu which shop?
  22. Rob'Z
    Rob'Z Formula 3
    Mar 29, 2008
    1,024
    Tucson,AZ
    Robert
    My engine ECU went bad. I installed a used/known working ECU and the engine fired up.
    Teffers likes this.
  23. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I understand my question was fir Rob from Canada
    I probably should buy a used F1 ecu but I thought usually they are pretty good. Especially in my 99 since it is inside.
