Please, help need on shift alignment! | FerrariChat
Discussion in 'Technical Q&A' started by christopher, Apr 11, 2006.
  1. christopher
    christopher Formula 3
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Hello fellow "F"-chatters,
    I'm going to attempt to align the shift fork with the shift lever inside the car.
    I could use some help as to what the fork position should look like to correspond with the shift lever inside the car. A picture would pain a thousand words. I'd be very grateful for your help!
    Oh, the car: a 79 308GTB
    Thank you very much!
    Chris.
  2. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Hey Guys,
    Your help is GREATLY appreciated!
    I'm going to try to tackle this over the week end!
    Thanks, Chris.
  3. Matt Morgan, "Kermit"
    Matt Morgan, "Kermit" Formula Junior
    Nov 12, 2003
    405
    Ferndale, WA
    IME, the trans shaft should be horizontal when neutral, although I have seen the tilted a slight amount (clockwise as seen looking at them). If careful you can move the shaft end and feel the edges of the shoft rods as yuo turn it. This is done with the trans in neutral, and a slight amount of pressure. Take care in moving the shift rods around, as you can engage a gear and rotate the shift shaft out of the slot. Makes it difficult to find where you are then.
  4. Matt Morgan, "Kermit"
    Nov 12, 2003
    405
    Ferndale, WA
    #4 Matt Morgan, "Kermit", Apr 12, 2006
  5. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Hey Kermit,
    Thank you!
    Might you have pics of inside the trans with the gear fork in place and corresponding gear selector in position!
    I'm trying to position the gear selector inside the trans aligning 1st, 2nd, 3rd, 4th and 5th. I just don't know how it's suppose to look when it's all aligned.
    Thank you,
    Chris.
  6. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    I figured a pic of the inside of the trans cavity might be a bit much to ask, my aplologies.
    Can anyone explain the three levers that seemed to have been actuated by the fork in the transmission. Perhaps I could align those if I could find out what gear they represent?
    Thank you very mcuh!
    Chris.
  7. Kingpin328
    Kingpin328 Formula Junior
    Nov 7, 2003
    433
    #7 Kingpin328, Apr 14, 2006
  8. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Chris,
    The best way to align the shift forks / shift lever is to take the bottom cover off the trans and watch what happens when someone is shifting thru the gears. Be careful when you remove the plate as there are 3 springs/ ball bearings that the plate holds in place. You can see the holes in the posted picture. Centralize the shifter as per the shop manual and turn the adjuster accordingly. You will find that a small amount of movement will make a big difference. After each attempt, have someone shift through the gears as you watch the action inside the trans. You'll get it, just take your time. While I'm sure you can do this job without taking down the plate, it will be a poke and hope approach. Good luck.
  9. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Gentlemen,
    Thank you very much for your replies!
    Thanks again,
    Chris.
  10. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Hello Guys,
    Just wanted to see if anyone else was interested in weighing in.
    Chris
  11. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Ditto...
    Also, it's important to have the detent springs & balls that are held in by the cover in place while doing the adj. Ensures the shafts are kept in the proper position for the adj. Easiest way is to make a tool that duplicates the end of the trans sump cover. Cut a piece of ~3/4" x 3/4" maple or oak from a piece of 1"x2" long enough to span several bolt holes on the sump end. Drill a hole in it the same depth as the one in the cover, & throu-holes for mounting it & use it to hold the balls & springs in place during the adj. It's easy to make once you have the cover as a pattern.
