Please Help | Page 5 | FerrariChat
Please Help
Discussion in 'Mondial' started by mondialqves, Dec 27, 2015.
  1. porchnut
    porchnut Formula Junior
    Dec 2, 2014
    282
    Tucson, AZ
    Andrew Bober
    WOW, I have been following this thread since the beginning and I am praying to the Ferrari Gods I don't ever have to experience this, this is mind blowing. Glad there are so many other owners that have the electrical knowledge and can help out.
    Andy
  2. moysiuan
    moysiuan F1 Rookie
    4,302
    Canada
    Agreed, I am really curious how this all turns out, that is some outstanding coaching going on here.
  3. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    I will try this tomorrow morning european time…and report back
  4. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Very true! The coaching will be compensated
  5. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Report: nearly 0
  6. Jeka
    Jeka Formula 3
    1,183
    Rotterdam
    Johan
    Ok, that's as expected!
    Now you can try to remove this double wired pin (spade) out of the connector J. If i am right it is secured by some barbs (púas). After removal of the pin reconnect connector J to the fusebox. You can leave the removed pin hanging there but be shure it won't touch anything. Now you can try if fuse 17 still blows, I expect (hope) not :)
  7. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Give me 5 minutes please
  8. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    report: It does not blow!
  9. Jeka
    Jeka Formula 3
    1,183
    Rotterdam
    Johan
    That's good! Now all should be fine except for the fog lights, license plate lights and a few check panel lights. Is everything working again including the headlights? And does your check panel work?
  10. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Give me 5 min
  11. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Everything works but: fog lights are disconnected and license plate lights too from the boot connector. Also the P light still appears instead the one that corresponds on the panel behind the steering wheel.
    Check panel works but yellow light is on showing some mistake
  12. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    I mean: the Parking light comes on instead of the headlight indicator light on the panel behind the steering wheel.
  13. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Panel lights are not working too
  14. Jeka
    Jeka Formula 3
    1,183
    Rotterdam
    Johan
    Parking light indicator instead of headlight indicator can give us a clue (i have to find out what the cause is). The foglight circuit does have a switch, indicator light and it is connected to the mileage unit. This is one of the circuits with possibly the short. Maybe there is a connection with the wrong parking light.
    What is the "panel light", is that the backlight of the instrument cluster?
  15. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Panel lights are all the panel lights from the instruments, rev, speed, and the central panel…still not working
  16. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    What do the pink wires belong to?
  17. Jeka
    Jeka Formula 3
    1,183
    Rotterdam
    Johan
    The pink wire belongs to the fog light circuit and the fog light indicator.
    The pink/yellow wire belongs to the license plate light and the check panel.
    In one of those circuits contains a short which is causing the trouble.
    Unfortunately we can't disconnect both wires from each other without cutting them :-(
    So we have to look at the fog light switch first to see of the short to ground is there. Disconnect the fog light switch an measure the resistance between the loose wire of connector J and ground.
    The panel lights seems another issue because they are feed by another circuit.
  18. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Ok, this I will do it tomorrow cause it takes me more time
  19. Jeka
    Jeka Formula 3
    1,183
    Rotterdam
    Johan
    I read your first post again and you mentioned side lights. They are not in the diagram so they may be part of the foglight or license plate light circuit!
    Before looking at the fog switch it is better to take a look at all the side lights and measure the resistance of the lights to ground. If you find a short, they are part of the circuit.
    In that case it is good to take a look at the side light connectors and the cabling to see if there is some visible damage. Maybe you can disconnect all the side lights and measure again the resistance of the loose pink wire to ground to see if this solves the short.
  20. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    I have time now…so give me some minutes
  21. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    All the testing was done with them disconnected
  22. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Report: is 0
  23. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Have tested them now reconnecting them. They work perfectly well with the indicators
  24. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Lets see if we can resolve this this weekend
  25. Jeka
    Jeka Formula 3
    1,183
    Rotterdam
    Johan
    Yes that would be nice :)
    What we know:
    1. There is no problem in the fusebox.
    2. Only one connection of connector J has a short circuit.
    3. The short circuit is either the foglight or the license plate light circuit.
    4. The short is not in the external foglight wiring from the fusebox (we did a check).
    5. The short is not in the license plate wiring in the trunk (is disconnected).
    6. The side lights are probably part of one of the circuits.
    7. The parking light indicator works as a headlight indicator.
    8. The instrument backlight does not work.
    Next thing to do is to be sure the side lights are all disconnected (I think all were disconnected). If they are and there is still a short measurable (pink cable) then I would:
    1. Look at the fog light switch. Because this switch is also connected to ground and is wired to the indicator lights. Disconnect the switch and then measure the resistance to ground of the pink cable.
