Please Help | Page 7 | FerrariChat
Please Help
Discussion in 'Mondial' started by mondialqves, Dec 27, 2015.
  1. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Connector is in very good shape. Thank you
  2. Jeka
    Jeka Formula 3
    1,183
    Rotterdam
    Johan
    #152 Jeka, Jan 16, 2016
    So the license plate/check control circuit is ok All connectors but one are disconnected and only the basic wiring harness is left and we see still a short to ground. This circuit is feed by the pink/yellow wire which is connected to the pink wire (connector J). The fault is in the wiring harness or in the other circuit.
    We checked the other circuit already for a large part but not completely. I think it is necessary to disconnect the instrument cluster connectors one by one. It might be very hard to do but i am afraid there is no other option. If you want to try this then start by the first connector, disconnect it and measure the pink wire (J connector) to ground. If it is still a short then disconnect the second connector and measure, in case of still a short then connector three. That leaves only the basic wiring harness.
    If there is still a short then the only cause left is a short in the wiring harness. To find this fault we have to disconnect wires. But that's for later (hope not).
  3. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Ok, give me some minutes…please and thank you
  4. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Questions….
    1- do you know where are they located?
    2- If there is a short, the measure should be infinite?
  5. Jeka
    Jeka Formula 3
    1,183
    Rotterdam
    Johan
    1. I unfortunately don't know were they are located.
    2. A short is 0 ohm (what we have now).
    If this is difficult and to avoid unnecessary hassle, there is a way to check if the problem is in the license plate circuit or this circuit. But to perform the check you have to disconnect the pink wire from the pink/yellow wire (the one we removed from connector J). For this you need to cut one of the wires and later reconnect them (solder!). I don't prefer this but if you can manage this... If you disconnected the wires then you can measure which one has 0 ohm to ground. After this you know for sure in which circuit the problem is.
  6. Jeka
    Jeka Formula 3
    1,183
    Rotterdam
    Johan
    Question: was the problem there at once or was it intermittent at first.
  7. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    I prefer not to cut the wire….Let me find out where these connectors are.
  8. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Connectors are near the steering column, difficult to get to…but I have managed to disconnect the first one. Still measures 0
    Should I connect back this one and disconnect the second or leave it disconnected and disconnect the second?
  9. Jeka
    Jeka Formula 3
    1,183
    Rotterdam
    Johan
    I think it is best to leave it disconnected for later measurements.
  10. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Here we are: have disconnected the second one with the first disconnected and still reports 0 but…have disconnected the third one (I think cause the clock does not work) and now it measures infinite!
  11. Jeka
    Jeka Formula 3
    1,183
    Rotterdam
    Johan
    Ok, it was the last one, that's Murphys law! :)
    Now you can reconnect everything (including the check panel connectors), except for this last connector. Then measure the pink wire again, it won't be infinite but higher than 1 ohm.
    If it's higher than 1 ohm you can put the removed spade (pink and pink/yellow wire) from connector J back in place and connect connector J. After this you can check if all systems are working again except for the odometer/clock and instrument backlight). Tomorrow we can find out what is wrong with the clock/odometer module.
  12. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Have connected the 2 connectors and the check control black connectors and it went back to 0 again …sniff
  13. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Ok, here is the thing
    I have disconnected connector 2 also and still 0. Then 1 again (so the 3 disconnected) and then 0 again and I have disconnected the check panel too and goes back to 1….so it seems that's all related...
  14. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    This means that the 3 connectors from the panel plus the black from the check controls are all disconnected and now is 1 ohm...
  15. dfranzen
    dfranzen Formula 3
    Aug 31, 2013
    1,577
    Ponte Vedra Beach , FL
    Don Franzen
    Johan you are doing an excellent job thanks for stepping in as there is a difference between US and Euro wiring!
    Mondialqves you are are not alone in your adventure we are all supporting the efforts that you are going through!
  16. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Many thanks! These words keep my "fighting" with this "cause"
  17. Jeka
    Jeka Formula 3
    1,183
    Rotterdam
    Johan
    Thanks! We have to find the cause although there is some unexpected intermittent behavior now. There is indeed a difference between the Euro and US diagrams. Unfortunately i only have the Euro version, i tried to find a US version but i did not found any.
    Regarding the issue: are all connectors disconnected including the two from the electronic control box in the foot well? Did i understand your clock didn't work before the issue?
    And it is incredible how you manage to find all those connectors and disconnecting them in such a fast way.
  18. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Cause I have half the car dismantled because of this issue
  19. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    All 3 connectors from the dash connectors disconnected but not the 2 from the electronic control box. Also disconnected the black from the check panel. Clock did work before.
  20. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Another test….if I connect the black connector from the check panel, the measure comes back to 0 again. If I disconnect it…it goes up to 1. This is done with the 3 connectors from the dash disconnected and with the electronic control box connected.
    This is how I am now
  21. Jeka
    Jeka Formula 3
    1,183
    Rotterdam
    Johan
    Please disconnect the two connectors of the electronic control box as well! Because this box is a feedthrough for all the lights on the back of the car.
  22. Alden
    Alden F1 Rookie
    3,777
    Central Florida
    Wow, 172 posts so far trying to find this issue, this is great perseverance guys!
    I am chasing some gremlins in my indicator panel too.
    Could you post a few pics of where the connectors are located since you have it all torn apart? This would be valuable for anyone reading this thread in the future too.
    I am specifically looking for where the connection from the panel indicator can be found. I have tried to see it by looking under the dash, but can't see the ends of the wires.
    It would be nice to know where it is before I start tearing my dash apart.
    Thanks,
    Alden
  23. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Ok, will do now and measure
  24. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Done and measures 1
  25. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Will place the photos when I reconnect them all. It is difficult to access, very….have to do it with the fingers without looking
