Please Help | Page 9 | FerrariChat
Please Help
Discussion in 'Mondial' started by mondialqves, Dec 27, 2015.
  1. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    If I put the 2 probes touching each other, the value is .000
  2. Jeka
    Jeka Formula 3
    1,181
    Rotterdam
    Johan
    Ok, now we can reconnect the connectors one by one.
    1. The electronic unit is already connected and it measures infinite, so this is good.
    2. The black connector of the check panel is connected, but we need a clear measurement. This one should be remeasured (three digit value).
    3. Reconnect connector one from the instrument cluster (the buttons) and measure (three digit value).
    4. Reconnect connector two from the instrument cluster (the lights) and measure (three digit value).
    5. Reconnect connector three from the instrument cluster (the clock) and measure (three digit value).
  3. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    I have an issue now! And I am getting worried: all connectors are back connected
    The stop light light in the check panel is on when I press the brake!!! Went back to the boot and disconnect but the bulb to check it but it is fine but I have noticed the following…..There are 2 bulbs with double filament each…..when I press the brake on the drivers side both are on but on the passenger side only one is on…
    I have a question…when I turn the lights on, on first position…..only one bulb is on... on each side, not both…..I mean…shouldn't both on each side be on… ? also….when I turn the P switch on…happens the same…only the lower bulbs are on….may be here is the issue?
    Also….the small bulbs that are suppose to illuminate the boot are not working….they were not working before I think
  4. Jeka
    Jeka Formula 3
    1,181
    Rotterdam
    Johan
    I would advise to first solve the first issue (blowing fuse 17), the measurements are important to take conclusions. The weird behavior can be explained because we disconnected a wire from connector J. I will look in the schematics about the single and double lamps.
  5. FCnew
    FCnew Formula Junior
    May 5, 2015
    687
    Hong Kong / Canada
    Jonathan
    I think you better post some pictures as you go...
    a picture is worth a thousand words.
    It will minimize any possible misunderstandings.
  6. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    This is how we are now after the failure in the brakes:
    1- All disconnected again: this means…3 connectors form the dash, the electronic unit and the black connector from the check control. Like this…measures: 1
    2- Wen I connect the electronic unit, measures: 0,003
  7. Jeka
    Jeka Formula 3
    1,181
    Rotterdam
    Johan
    I don't think there was a misunderstanding, only a misinterpretation of the measurements. But at least two valuable conclusions are valid:
    1. Fuse 17 does not blow if the wire of connector J is disconnected so the fusebox is probably ok.
    2. If all buttons, lamps and units are disconnected there is no short measurable so the wiring harness is probably ok.
    I am sure we will find the cause! But it takes some time.
  8. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    I hope we do find the cause...
  9. Jeka
    Jeka Formula 3
    1,181
    Rotterdam
    Johan
    #209 Jeka, Jan 17, 2016
    That's 3 ohm, this is a relatively low value. I would advise to disconnect the blue connector of this unit and only connect the green one and measure again.
  10. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Done:
    If I connect any of them back, value is still 1
    If I connect both at the same time, value comes down to 0,003
    So…when both are connected to the unit, value comes down
  11. Jeka
    Jeka Formula 3
    1,181
    Rotterdam
    Johan
    In that case only connect the green one.
    Then connect the black connector of the check panel and measure again.
  12. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    If I connect the connector that has a green (verdi) wire (for me comes from the lower part of the electronic unit, not from the upper part as shown in your diagram. The connector that comes from the upper part for me is composed mainly by reds and yellows wires), stays in 1 but when I connect the black switch in the control panel….the numbers just go crazy from 0.006 to 1.4……..
  13. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    by go crazy I mean that they do not stop moving
  14. Jeka
    Jeka Formula 3
    1,181
    Rotterdam
    Johan
    It is the connector with on two places a double and-or triple wire.
    You should not switch the ignition on when measuring. I think the measurement will be stable when you switch off the ignition.
  15. Jeka
    Jeka Formula 3
    1,181
    Rotterdam
    Johan
    I forgot to say, the light switch should be in the "off" position. So everything is switched off.
  16. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Ignition and light switch is in off position always. They go crazy when I move the central panel...
  17. Jeka
    Jeka Formula 3
    1,181
    Rotterdam
    Johan
    After measuring this one you can measure the rest (all with ignition and all lights off):
    1. Reconnect connector one from the instrument cluster (the buttons) and measure (three digit value).
    2. Reconnect connector two from the instrument cluster (the lights) and measure (three digit value).
    3. Reconnect connector three from the instrument cluster (the clock) and measure (three digit value).
  18. Jeka
    Jeka Formula 3
    1,181
    Rotterdam
    Johan
    Ok, maybe there is our problem!
    Disconnect the black connector and proceed with the three instrument cluster connectors.
  19. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Thats the connector. It stabilizes at 0,415 but if I move the connector ….it goes crazy
  20. Jeka
    Jeka Formula 3
    1,181
    Rotterdam
    Johan
    I advise to leave this black connector disconnected, we will find out later what the problem is. Now it is time for the three instrument cluster connectors. I am very curious about the results :)
  21. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Black connector disconnected and measure report: 1
    If you do not mind, I will continue tomorrow…very tired and my mind is not "connecting" at the moment. Let's hope that we will resolve it this week.
    Again, many many thanks!
  22. Jeka
    Jeka Formula 3
    1,181
    Rotterdam
    Johan
    No problem, it's my pleasure. :) We are making realy progress now so i am very confident we will find the issue soon!
  23. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Back from the office. I will do the measures in while
  24. Bell Bloke
    Bell Bloke Formula 3
    Dec 6, 2012
    1,839
    Mayday, mayday!!
    I'm in a light plane over Rotterdam, the pilot's got stuck in the toilet with a stewardess and the co pilot is drunk. I'm the only guy here that can land this baby BUT I need someone to talk me down to the ground in this thing.
    Is there a 'Johan' in the house?!
    Seriously Chaps, great job we are in the edge of our seat here i the UK!
    https://www.youtube.com/watch?v=SmHeP9Sve48
  25. mondialqves
    mondialqves Karting
    Dec 27, 2015
    176
    Barcelona, Spain
    Good nite…too tired to continue today. I will tomorrow, you have my word…sorry…to many hours working in the office today
