Pls recommend me good small business WiFi router (under $1k) | FerrariChat
Discussion in 'Technology' started by valter, Oct 21, 2014.
  1. valter
    valter F1 Rookie
    2,871
    Nibiru
    Vlad
    I was fine with consumer grade models from Netgear, Linksys, etc. until I got a bit more devices in the network. Arghhhhh.... they all either randomly hang, overheat, issue duplicate addresses or something. Recently another $250 router went south. I swear, in the last year I went through 3 of them.
    Is there such thing as gigabit router with WiFi (2.4 & 5 Ghz) that can handle 30+ devices simultaneously for more then a few month which is not too expensive - under 1k? Thank you!
  2. Edward 96GTS
    Edward 96GTS F1 World Champ
    10,988
    and to piggyback on this if you dont mind, any recommendations for a good wifi range extender?
  3. 404Redirect
    404Redirect Rookie
    Sep 4, 2013
    4
    Tulsa, OK
    Jim
    Valter, I have separated the duty of WiFi and switching away from my router and went with the Cisco RV042 for Routing, Ubiquiti UniFi AP for Wifi and HP ProCurve gigabit switch. All have been in place for quite a long time with well over 30 devices connected and my only downtime was my fault for flipping a number in one of the settings.
    I have not tried it yet myself but an inexpensive device that is getting great reviews and fits both your and Edward's needs is the Securifi Almond...odd name I know...but the feature set for the price point is pretty crazy.
    Amazon.com: Securifi Almond - (3 Minute Setup) Touchscreen Wireless Router / Range Extender: Computers & Accessories
    Hope this helps.
  4. Gran Drewismo
    Gran Drewismo F1 Rookie
    Jan 24, 2005
    3,778
    Idaho
    Andrew
    Do you need to have your routing and wifi all in one? Because the best wifi access point I have come across in years is the Apple Airport Extreme.
    Seriously.
    We have several in each of our offices and they work like champs. 50 users maximum.
    Now of course our switching and routing is handled by Enterasys C5 switches so that does help big time.
  5. valter
    valter F1 Rookie
    2,871
    Nibiru
    Vlad
  6. Evolved
    Evolved F1 Veteran
    Nov 5, 2003
    8,700
    I use all Cisco hardware. I like being able to sleep at night and take vacations instead of getting phone calls.
  7. Ricambi America
    Sponsor Owner
    +1.
    We use the Cisco 861 series. Crazy complex to configure, but done properly it is rock solid.
  8. dsd
    dsd F1 Rookie
    Nov 19, 2006
    4,260
    Northern Virginia
    I think AeroHive makes the best controller-less WiFi out there.
    Price point is where you want it. 30 users starts to push commercial and the need for higher association rates and the like.
    I'd checkout Aerohive or a used commercial system from eBay.
    -dsd
  9. valter
    valter F1 Rookie
    2,871
    Nibiru
    Vlad
    Thank you again guys! Proud to report that I completed first phase - got Cisco RV325 router. What a nice piece of hardware! It's been running for only 2 days now, but everything works GREAT, lots of configuration options , UI fast and it runs really cool. Temporarily I switched my old routers to Access Point mode with all other stuff disabled, and connected to Cisco they provide WiFi. Works great.
    Next step would be getting some real Access Points... Thanks again for the right direction and recommendations!
  10. bounty
    bounty F1 Veteran
    Feb 18, 2006
    7,769
    San Diego, CA
    I'd give GTHill a PM - he's a leading expert in this area.
  11. SmellyPenguin
    SmellyPenguin Rookie
    Dec 25, 2007
    33
    CA
    I'd recommend getting a seperate Router and Wireless Access Point, if you just need one access point you can get away without getting the wireless controller.
    Router recommendations: Sonicwall, Cisco
    WAP recommendations: Cisco Aironet, Ruckus
    Be wary of the small business branded Cisco products, as they are usually rebadged from their Linksys line.
  12. valter
    valter F1 Rookie
    2,871
    Nibiru
    Vlad
    Just an update - my Cisco is still working like tank, no failures, no problems at all... Thanks again!
  13. GTHill
    GTHill F1 World Champ
    Jul 1, 2006
    14,054
    Double Wide
    GT Hill
    Thank you sir! I'll help however I can.
    GT
  14. tjacoby
    tjacoby F1 Rookie
    Nov 1, 2003
    2,857
    Vancouver Canada
    tj
    GTHill defn knows his stuff - but also take a look at the Cisco Meraki line: much simpler to support than the traditional Cisco stuff.
