Plug a battery pack into lighter while changing battery? | FerrariChat
Discussion in '348/355' started by vracer, Jul 16, 2014.
  1. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    I'm preemptively changing battery tomorrow that is a minimum of 3.5 years old. I'm assuming that the best way to keep middle aged electronics happy is to keep them juiced. Any counter thoughts?
    Thanx,
  2. Volair
    Volair Karting
    Apr 11, 2013
    241
    Carmel, Indiana
    Bart
    Not necessary. You will have to reset the clock. That's about it.
  3. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
  4. bikz
    bikz Formula 3
    Mar 2, 2012
    1,043
    Malaysia
    well at least for the 348 2.7M i think you gotta start it up and not do anything for a good ten min till the fans kick in while the ecu is learning all the new parameters.....
  5. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    Yes, any mass air flow injection system records it's fuel maps at idle and throughout out the rpm range under different loads and is contiuosly adjusting them and "learning" the best air fuel mixture for the load/throttle position/rpm etc. The only hard map that doesn't change is wide open throttle on most. When you kill power all the "learning" is lost and has to remap. Not a big deal but the car is not at it's best until some idle time and a good cruise.
  6. vracer
    vracer Formula 3
    Jun 23, 2014
    1,098
    NorCal
    Richard
    Thanks, Guys. Stories of blown airbag ecus, etc. make me apprehensive.
  7. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    I've heard of electric damage from jump starts but not powering down and back up. Heck it has a built in battery cut off switch.
  8. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Shut the battery off before changing and all will be fine.
