My oldest daughter is spending the summer at my beach house. She called this AM with a bathroom crisis. The toilet was running. OK, I solved the crisis pretty easy with a telephone walk thru of "chain jiggling". But thats not the problem. The problem is, she said after it ran for a long time the water turned HOT. Hmmm....... I've heard occasionally plumbers hook up hot to toilets to prevent condensation on the tank, but do they really do that? Do you think it could be hooked to the hot by mistake? How wasteful would that be?
IANAP, but one check could be to turn on just the hot water in the bathroom sink, then flush the toilet and see if there's reduced flow at the faucet.
It does happen periodically. It wouldn't be wasteful at all, if the toilet did not "run" when it wasn't supposed to. If it continually runs, then it will be very wasteful. A good way to check is just to turn off the hot water out pipe from the hot water heater. Turn on your hot water only, at a sink. NOTHING should come out. Now flush the toilet, if the toilet fills, it's filling with cold water...............if it doesn't fill, it's connected to the hot water. It's not a big deal at all, unless for some reason down the road, the toilet continually runs.
Did you ask her the color of the urine, to see if she had been having a "piss up" at the Beach House? I am not a plumber and I did not stay at a Holliday Inn Express last night. Sorry.
Never heard of it, but it makes sense. I doubt it would be wasteful. The story reminded me when my son called me in Minnesota from L.A. that the tub was about to overflow. Response should have been "I'll be right there!"
And now the Horsefly observation: Being a night owl, I was watching one of those late night home improvement shows. On one show, they were installing a "mixing valve" into the water line that feeds the toilet tank. Just as you mentioned, condensation on the side of the tank is a problem in humid environments when the tank is feed from the cold water line. SO, the cure to the problem is a small mixing valve that pipes a SMALL amount of hot water into the cold water line that feeds the tank. This raises the temperature of the water just enough so that it won't cool the tank enough to cause condensation on the outside of the tank. Perhaps there is a mixing valve somewhere that is clogged up or adjusted wrong.
Maybe because this is a coastal home they might connect to hot so pipes wont freeze but I've never heard that. How did she know the water was hot? Was she standing in it? Was it just warm? Sometimes on hot days pipes can warm the cold side, esp. if non insultated copper.
You know, I wondered that as well. I've noticed in that bathroom, you run cold in the sink and after about a minute it gets fairly hot, but 5 minutes later its cold again; I thought it might be a pipe in a hot wall or something.
Very poss.... you might want to check insulation in this wall if you keep the water turned on in the winter months. I suggest you cut it at the main during any months freezing is a poss. GL You should also teach your girls, when they get home, that there is a shut off valve under the toilet and how to use it...... simple lessons in life "dad".... Their husbands will thank you.
I gave her a little inservice on the fuse box and the water valves. Showed her the "T" tool for cutting it off at the street. We went out there , I pulled the cover off, the hole was full of pine straw and fire ants, i stuck my hand in there and quickly flipped out the straw and ants, and scrapped the dirt away from the in-line valve and showed her how to shut it down if there is a leak. I could tell the dirt and fire ants were a little more real life than she wanted for her summer at the beach...."ewwwwwwwww"
Strange knocks on the door late at night: Smith & Wesson Airweight 5 shot revolver. 38 caliber. Load with 4 rounds for safety and leave hammer down on empty chamber. Smaller than other big revolvers and a good fit for smaller hands. No safety or clips to fiddle with. Simply point and pull the trigger. Knock knock. Who's there? Burglar with 38 slug in his chest. Thud.
Negatory good buddy......... Shotgun, short barrel with 6 rounds alternating slug, buck shot, shoot in the ceiling first then aim "near" the person. A very clear message. Yes, I've tought my wife this..... don't even think about it. There are cops that used to carry 38s that could hit the side of a barn with it.
