Polish for Clear Coat Bra Protector f430 | FerrariChat
Discussion in 'Detailing & Showroom' started by Rainmaker Ferrari, Jun 21, 2011.
  1. Rainmaker Ferrari
    Jun 21, 2011
    44
    Lansdale PA
    Scott
    Does anyone use a polish for the Bra or do you just clean it with water?
    Thank you in advance
  2. Apple Sauce
    Apple Sauce Formula Junior
    Jun 30, 2008
    626
    Wide Open Throttle
    Vic
    I'd go straight over to the best detail shop you can locate and ask them.
    I've used Meguiar's NXT as a wax with no ill effects.
    Many of the car detail— wax companies have developed safe cleaners for clear film that may be better than the NXT I've been using, I will assume.
  3. Rainmaker Ferrari
    Jun 21, 2011
    44
    Lansdale PA
    Scott
  4. bryonj
    bryonj Karting
    Jan 20, 2010
    111
    Naples, FL.
    Brian
    Plexus is the best I've found. Works good on keeping bugs from sticking. Seems to also moisturize material. They use it a lot on airplanes lexon(?) windows.
  5. Rainmaker Ferrari
    Jun 21, 2011
    44
    Lansdale PA
    Scott
    Great !Thanks
  6. elpadrino
    elpadrino Formula Junior
    Aug 29, 2005
    694
    Bogota NJ
    Gabriel
    Adam's Polishes makes a good clear bra polish.
  7. JoshVette
    JoshVette Formula Junior
    Aug 12, 2007
    708
    Grand Prairie/Dallas
    Josh
    Are you talking about simply cleaning the film?? or actually polishing it as you would the paint to remove swirls and such blemishes??
    If cleaning I like Plastix from Meguiars, if polishing out swirls, I would refer a finish polish with a very soft pad as film is much more delicate then paint.
    Josh
  8. Apple Sauce
    Jun 30, 2008
    626
    Wide Open Throttle
    Vic
    I would call the manufacturer of the film for their advise.
    A little google searching will bring up their numbers
  9. cig1
    cig1 F1 Rookie
    May 3, 2005
    2,914
    In front of you
    #9 cig1, Jun 22, 2011
    This came recommended to me by the clear film distributer/installer
    g
  10. alum04org
    alum04org F1 Rookie
    4,748
    Plymouth, MI
    Same. Recommended by my 3M clear film installer and has many other "household applications."
  11. Rainmaker Ferrari
    Jun 21, 2011
    44
    Lansdale PA
    Scott
    Thank you for all whome have replied
  12. carwasher
    carwasher Rookie
    Nov 30, 2006
    17
    Central PA
    Jon Rose
    Plexus is a bad idea. Spray a little in a glass and let it dry out. It leaves a yellow residue. On your clear bra it can lead to the film turning yellow. There are many different films and they all respond differently. In general most films have a very thin clean coat that can be polished and waxed. Most films can be buffed with a high speed buffer if the person doing the buffing knows what they are doing. NXT should be good for your car. Just keep clear of the edges so you don't get a white residue.
