Polish my shift knob (clean) | FerrariChat
Discussion in '456/550/575' started by Knightowl, Jun 25, 2020.
  1. Knightowl
    Knightowl Rookie
    Aug 11, 2019
    8
    Christopher Lee
    Has anyone every tried to refinish a shift knob or similar part? Mine has a ton of scratches and I'm curious if there is a way to polish it or refinish it so it looks new again.
  2. tazandjan
    38,083
    Has been done with the 3 pedal knobs/balls so no reason it will not work on yours.
  3. Knightowl
    Knightowl Rookie
    Aug 11, 2019
    8
    Christopher Lee
    Any leads on where I might take it to get that done?
  4. tazandjan
    38,083
    Any machine shop can use a buffing wheel and compound to make it shine. Good idea to clear coat afterwards. Or you can use a drill with a buffing wheel and a compound stick yourself. Not hard to do at all.
  5. 308 GTB
    308 GTB F1 World Champ
    11,190
    New Jersey
    Barry Wolinsky
  6. hwyman
    hwyman Formula Junior
    Jun 25, 2015
    329
    Canada / Los Angeles
    It has a clear coat that comes of in patches and looks like crap. I sanded off lightly with a 600 grit then used compound to polish it to a mirror shine
  7. 456M GTA
    456M GTA Karting
    hwyman, is spot on judging by the photo - likely the clear coat - I also have a is a patch on my own gear shift which is hard to stop picking at!!
  8. ixlr8
    ixlr8 Formula Junior
    Aug 24, 2015
    302
    Eastern Shore- Virginia
    Jim
    The clear coat on mine is coming off in chunks, but the knob is also scratched up like a previous owner was wearing rings on their right hand. It is going to take some sanding/buffing to clean up the mess I have. Might be easier to just replace it with new.
  9. brogenville
    brogenville Formula 3
    2,020
    Robin
    I’ve done several gear knob refurbs. Top tip is to get an M10 bolt (I think- need to confirm), then mount the bolt in a drill press, and use the spinning drill to do most of the buffing work. Start with a coarse compound to cut the lacquer off, then when it’s away start going finer. I used a DA polisher on the knob with it spinning in the drill at the same time to get the final mirror finish.
  10. hwyman
    Jun 25, 2015
    329
    Thats what I did too, mounted it in a drill
  11. 308 GTB
    11,190
    New Jersey
    Barry Wolinsky
    I didn't know these shift knobs came in a highly-polished mirror finish. Both my F355 Challenge and 550's shift knobs are a satin anodized finish...
