Poll 355 Valve guides | Page 2 | FerrariChat
Discussion in '348/355' started by Merdav, Nov 14, 2004.
Have had your 355 valve guides replaced?
  1. Yes, my valve guides were shot.
  2. No, my valve guides have never been a issue.
Multiple votes are allowed.
Results are only viewable after voting.
  1. F355Berlinetta
    F355Berlinetta Formula Junior
    On my 1995B the valves guides were replaced in addition to an engine rebuild due to poor compression results. The final bill was unspeakable. Luckily all this was done by the previous owner who threw in the towel after this fiasco.
  2. JoeG54
    JoeG54 Karting
    Aug 24, 2004
    183
    Bay Area, CA
    Joe G
    May I ask what specifically constitutes "poor compression results", i.e. what were the compression values?
    Thanks very much,
    Joe
  3. 348SStb
    348SStb F1 Rookie
    I can't speak about compression values, but in a leakdown test, less than 10% leakage of each cylinder means you're in good shape. The leak down test on my 348 before I bought it showed each of the 8 cylinders leaking only 5 or 6%.
  4. F355Berlinetta
    I have all the receipts, none of which show the compression numbers.
  5. mondial86
    mondial86 Formula Junior
    Nov 1, 2003
    298
    MA
    David Holmes
  6. 348SStb
    348SStb F1 Rookie
    I'm not a mechanic, but I remember being told that a leak-down test is an indication of whether or not there's good compression...
    I was told that doing a compression test as well as a leak-down test would be superfluous--that a leak-down test is good enough... I dunno
  7. Joe G.
    Joe G. Formula 3
    1,109
    Los Angeles
    Joe Gazzani
    personally i think that ALL F355's pre '98 WILL HAVE the valve guide problem
    if not before 30k, then before 40k, 50k, or 60k miles.
    personally i think there is NO WAY a pre '98 F355 will go past "let's say 75k miles" without needing a valve job
    this is sad when you can get 125k miles out of a 328 without any top end problems or bottom end problems
    the future will tell
  8. Rifledriver
    37,288
    I agree with Dave on this. Of the many things I learned on my trips to Maranello one of the things I found so striking was in the production of the engines were a sometimes quizzical combination of high tech and old world methodolgy. A great deal of old fashioned hand work is involved in the production and assy of the cylinder heads. It was admitted to us on several occasions that turn over was very high and I believe that spotty quality work is sometimes the price paid for that. I have many times taken apart cyl heads to find valve seals smashed or broken in various ways that can only be accounted for by assy problems. I recently saw a 360 motor with it's oil pan off that had the #4 main bearing laying against the windage tray with both nuts and washers laying in the oil pan (this was not causing any noticable problems). I have to believe that other problems such as those mentioned by Dave happen too, it's just impossible to prove by the time we get in there to see it. We had a 97 or 98 355 burn a valve at 7 or 8k miles, when we got a look at it, it was obvious that the seat was WAY to thin to last. I have also seen 355's go many, many miles with out incident. I don't think the QA problems are new, Ferrari goes through cycles of it. The difference is now IMO that the cars are highly enough stressed that you can't get away with much.
  9. lawwdog
    lawwdog Formula 3
    Dec 4, 2002
    1,178
    Northern California
    Mario
    No valve guide issues to speak of here.
    97 355 spider 18K Miles
    When I bought my car Ferrari of S.F. did a compression test in Bar's
    My results
    Cylinder #1 = 12.5 Bar
    Cylinder #2 = 13.5 Bar
    Cylinder #3 = 12.5 Bar
    Cylinder #4 = 12.5 Bar
    Cylinder #5 = 13 Bar
    Cylinder #6 = 13.5 Bar
    Cylinder #7 = 13.75 Bar
    Cylinder #8 = 13.75 Bar
    All told Compression % of 185 - 215 ..... Just as the factory wanted !!!
    This from the MotoMeter print out I received. No valve guide issue here.
    Mario
    P.S. My car is for sale... I want a Red/Tan 355B
  10. lawwdog
    lawwdog Formula 3
    Dec 4, 2002
    1,178
    Northern California
    Mario
    I did have valve guides replaced on my prior 95 Red/Back 355B at 17K miles.
    I voted twice.
    Mario
  11. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Problem with the comp. test and leak down tests are they will only show if there is carbon on the seat or valve, or if the valve is not seated properly. If not, the results will show fine. On the first 97 I did the comp and leak tests showed only 2 cylinders with a problem. When dissambled every valve in both heads were ready to change holes. There was no question as to if there was a problem with the guides as the head of the valve could be moved side to side in excess of 3/16". This is grounds to condemn a Chevy with 3/8" dia. valve stems.
    As Brian said, at 8K+ RPM there is little room for error.
    Dave
  12. ghost
    ghost F1 World Champ
    Dec 10, 2003
    10,046
    Singapore
    How'd you do that? :confused:
  13. Rifledriver
    37,288
    He did it once in FL. and once in NY.
  14. Merdav
    Merdav Formula Junior
    Apr 11, 2004
    980
    Not everyone who voted on the poll entered the model year but here is the tally from those who did so far.
    95's-4 good
    95's-2 replaced
    97's-2 good
    98's-1 good
    98's-1 replaced
    99's-1 good
    so only 11 out of 34 posted thier car years
  15. tonyc
    tonyc Formula 3
    Oct 19, 2003
    1,676
    Monterey, CA
    Tony C
    Hi Michael,
    Before I purchased my F355 I looked into the valve guide issue and was told
    to make sure I get a car with an assembly number greater than 27689 by a F-car tech at a dealership......they just happened to have one :)
    Another interesting poll would be something like this, if it could be done:
    95 355 valve guide problem: Y/N
    96 355 valve guide problem: Y/N
    97 355 valve guide problem: Y/N
    98 355 valve guide problem: Y/N
    99 355 valve guide problem: Y/N
    --tony
  16. Merdav
    Apr 11, 2004
    980
    That would be much more accurate, but thats 10 possible choices, you can only poll up to 5 I think.
  17. jakermc
    jakermc Formula 3
    Jan 17, 2004
    1,804
    Palm Beach, FL
    Rob
    My '98 GTS with September '97 build date had the valve guides replaced at 12K miles.
  18. ghost
    Dec 10, 2003
    10,046
    Singapore
    Aren't some of these valve guide replacements preventative measures. Ie, the car did not have any symptoms of valve guide issues, but the owner nonetheless had the guides changed for peace of mind. Those should be flagged, and not given any credit to for purposes of this poll, right Michael?
  19. 348SStb
    348SStb F1 Rookie
    Come on, that doesn't matter; they're "an issue" if they're replaced...
    Let's keep partisan ship out of this!
  20. Rifledriver
    37,288
    I have been fixing these things a long time and I've never heard of someone changing valve guides because they might go bad, but then I hear of people changing waterpumps because they might go bad.
  21. Merdav
    Apr 11, 2004
    980
    Well David you did write
    "So if you have a '95-'97 (and some '98s) car, I would say that you should swallow the bitter pill of spending a few thousand dollars to save over $20 thousand."-This is kinda a silly quote anyway, considering bad guides will not "damage" the engine, maybe burn some oil, rough idle, or smoke, but they dont just go bad at once, IF they wear out it is a fairly slow process. There is no threat to the engines intergrity.
    So yes I do believe many people have fallen into this "have them done while the engines out" business whether thier good or not, to avoid the 23.68% chance that they MAY go bad.
    The poll should have stated, WHO HAD THIER VALVE GUIDES REPLACED BECAUSE THE GUIDES AND ONLY THE GUIDES WERE BAD?"
  22. DIGMAN52
    DIGMAN52 F1 Rookie
    4,109
    Dallas Texas
    Philip C
    While tracking my '95 355 at the Texas Driver Magazine event at Motorsport Ranch, I broke an exhaust valve, caused by a bad valve guide. What Norwood discovered was one bank that showed pretty good on the leak down, and one that didn't. I am choosing to replace all them while we are in there so it will become a non-problem on any sale in the future. While in there, we are rebuilding the water pump, and doing all other normal maintenence.
    People had noticed some smoke out of one side under acceleration, but I never noticed it down on power until the valve broke, and I could hear extra exhaust noise. I had just seen some increased oil usage, so it had been coming for a while. Bad news is I'm down for about a month.
    So in my little over a year ownership I have fixed the seat guide/convertible top issue, bad exhaust header issue, and now these guides. I hope to hell I have a car I can enjoy for years to come without these costly glitches. A few cruises with the top down should solve this depression.
    Still love my
  23. Merdav
    Apr 11, 2004
    980
    Wow, sorry bout all the bad luck, but how did a worn guide break the valve (stem) I assume? Was it so worn that the cam lobe actually caught it on the angle and bent it in the head?
  24. 348SStb
    348SStb F1 Rookie
    Boy Michael you better pray this valve guide thing never happens to you!!! I'll say a prayer for you too because I hope it doesn't...
  25. FLATOUTRACING
    FLATOUTRACING F1 Rookie
    Aug 20, 2001
    2,684
    East Coast
    Jon K.
