POLL: If F80 were offered with different engine choices | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Eilig, Jul 22, 2025 at 8:22 AM.
If F80 were offered with choice of engines, I'd choose:
  1. Unassisted NA V12 that revs to 10k
    32 vote(s)
    66.7%
  2. Unassisted turbo V8
    0 vote(s)
    0.0%
  3. Assisted (hybrid) turbo V6
    16 vote(s)
    33.3%
  1. Eilig
    Eilig F1 Rookie
    4,135
    Tänzelndes Pferd
    Which would you choose, and why?
  2. Eilig
    Eilig F1 Rookie
    4,135
    Tänzelndes Pferd
  3. Enzo Belair
    Enzo Belair Formula 3
    1,591
    Texas
    Scott
    I chose the current powertrain, I am not a fan of V12's, particularly NA V12's. I like low end torque, light weight engines and the V12 is just not the answer. IMHO
  4. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,746
    ESP
    Bas
    You'll be surprised just how heavy the V6 is.
    Base engine is 185 kg (I assume this does include turbos, not sure about ancillaries such as intercoolers and associated piping, but for arguments sake assume it does)
    Battery pack 25kg
    Electric engine 22kg x3 (excludes all the heavy cabling etc)
    276kg
    F140 V12 weighs 205kg.
    Cosworth RA (Valkyrie engine, 6.5 liter V12) 206 kg
    Cosworth GMA (T50 engine) 178 kg (But crucially this includes the FULL exhaust system even for road car, including cats etc)
    A lightweight car with a high revving V12 (so "gutless" low down torque wise) will suddenly feel very quick indeed as it just has no weight to push forwards.
    Johnny_Bravo, MDEL, ab08 and 2 others like this.
  5. day355
    day355 F1 Rookie
    Jun 25, 2006
    2,584
    Many thanks for restoring the truth and debunking the myth of the small lightweight V6, which it is not due to hybridization.
  6. willcrook
    willcrook F1 Rookie
    2,702
    if the performance was identical or better to what it is now then the V12, otherwise keep it as it is
    jumpinjohn likes this.
  7. Caeruleus11
    Caeruleus11 F1 World Champ
    11,620
    I think the V6 power unit’s biggest advantages are packaging and torque.
    Enzo Belair likes this.
  8. Eilig
    Eilig F1 Rookie
    4,135
    Tänzelndes Pferd
    You clearly don't know what you don't know. LaFerrari V12 (engine only) weighs only 65 lbs more than 458 Speciale V8. I know. I've weighed them both, on same scale, on same day.
    65 lbs = half a tank of fuel = less than half the weight of passenger seated beside you. That is NOT much weight.
    Johnny_Bravo, Bas, day355 and 5 others like this.
  9. Eilig
    Eilig F1 Rookie
    4,135
    Tänzelndes Pferd
    V12 can easily package in F80. Just like it packages in SP3.
    V12's 500+ ft/lbs torque is plenty in a vehicle weighing less. Getting rid of batteries, electric motors, associated cables, etc reduces significant weight.
    Some of us still prefer engines over "power units."
  10. Eilig
    Eilig F1 Rookie
    4,135
    Tänzelndes Pferd
    Oh and adding even MORE weight to hybrid-turbo V6 setup are heat exchangers/intercoolers to facilitate necessary delta-T's for massive hyperthermal production of said "power adder" components, along with corresponding fluids @ 8.7 lbs/gal.
    You have no idea.
    Johnny_Bravo and Bas like this.
  11. Enzo Belair
    1,591
    Texas
    Scott
    Engines are power units. let me see if this helps. Yes you can package a V12 into the F80 but there is more to just fitting it into the car, its how well you can package and engine and what the results yield (dimensionality and weight distribution).
    F80 Hybrid vs. F140 V12
    Specific Output
      • V6: ~395 hp/L (900 hp from 3.0L)
      • V12: ~126 hp/L (819 hp from 6.5L) → V6 delivers nearly 3x the power density.
    • Thermal Efficiency
      • V6: >41% (boosted by lean burn, HPDI, and 3.7 bar boost)
      • V12: ~33% (limited by NA combustion and frictional losses) → V6 extracts more energy per unit of fuel.
    • Boost Strategy
      • V6: Twin 48V e-turbos spinning to 130,000 rpm for instant boost
      • V12: No forced induction → V6 achieves higher cylinder pressures and faster spool.
    • Torque Delivery
      • V6: >900 Nm from 0 RPM via tri-motor hybrid system
      • V12: 678 Nm at 7,250 RPM → V6 offers full torque instantly; V12 requires high revs.
    • Transient Response Time
      • V6: <100 ms (electric motors + e-turbos)
      • V12: >250 ms (mechanical throttle and inertia) → V6 reacts more than twice as fast.
    • Maximum Engine Speed
      • V6: 9,000 rpm (dynamic limiter at 9,200 rpm)
      • V12: 9,500 rpm → V12 revs higher, but V6 achieves more power per rev.
    • Packaging and Mass Efficiency
      • V6: Compact, rear-tilted layout with transverse battery
      • V12: Longitudinal, front-heavy configuration → V6 enables better weight distribution and aero centralization.
    • Center of Gravity & Chassis Integration
      • V6: Low-mounted ICE + battery behind cockpit
      • V12: Higher engine placement due to block size → V6 improves roll stiffness, lateral grip, and yaw agility.
    • Aerodynamic Compatibility
      • V6: Allows 1800 mm diffuser and active aero surfaces
      • V12: Bulk limits underbody airflow and diffuser volume → V6 supports higher downforce and lower drag.
    • Torque Vectoring & Lateral Control
      • V6: Dual front motors enable predictive yaw modulation
      • V12: Relies on mechanical LSD and passive steering → V6 offers superior cornering precision and stability.
    • Energy Recovery & Efficiency
      • V6: Regenerative braking + MGU-K recharge strategy
      • V12: No energy recovery → V6 improves endurance and reduces thermal load.
    • System-Level Control
      • V6: Ferrari’s Vehicle Dynamics Control Module blends ICE/EV torque
      • V12: Traditional ECU with gear-dependent torque shaping → V6 offers seamless power delivery and traction envelope optimization.
    • Reliability Under Load
      • V6: Derived from Le Mans-winning 499P; built for endurance
      • V12: Susceptible to thermal soak and over-rev stress → V6 maintains peak output under sustained track conditions.
    • Scalability & Future-Proofing
      • V6: Compatible with evolving battery tech and electric motor upgrades
      • V12: Physically and thermally maxed out → V6 supports long-term performance evolution
  12. Eilig
    Eilig F1 Rookie
    4,135
    Tänzelndes Pferd
    #12 Eilig, Jul 23, 2025 at 11:02 AM
    What your copied/pasted sales/marketing points do not take into consideration is the held-truth in physics (First Law of Thermodynamics) that you can't get something for nothing. Each of your cited "improvements" comes at both short-term and long-term "costs," and I'm not referring to the financial variety. Go study engineering for a deeper understanding.
    Johnny_Bravo, Bas and jumpinjohn like this.
  13. ScrappyB
    ScrappyB Formula 3
    Oct 3, 2017
    1,649
    Asked another way - would owners give up 15% in outright performance for a 100% increase in sound and emotion?
    Yes: 100%
    Johnny_Bravo, JohnMH, Bas and 5 others like this.
  14. Eilig
    Eilig F1 Rookie
    4,135
    Tänzelndes Pferd
    Wrong. Engines are one of the components of a power unit.
    "Power unit" is a newish term that wasn't used until turbo/KERS V6 F1 cars were put in use. It refers to the sum total of ICE + regenerative KERS + electric motors.
    ICE = Internal Combustion Engine.
    Power Unit = ICE + KERS + electric motors.
    Specifically:
    In Formula 1, a power unit refers to the entire powertrain of the car, encompassing the internal combustion engine (ICE) and the energy recovery systems (ERS). It's a hybrid system combining a 1.6-liter V6 turbocharged engine with electric motors and energy recovery systems.
  15. Enzo Belair
    1,591
    Texas
    Scott
    Not 100% accurate. An ICE engine in an automotive application is considered a power unit as a solo element. In terms of a hybrid system an ICE engine is one component of a power unit. The term is acceptable in both contexts.
  16. Eilig
    Eilig F1 Rookie
    4,135
    Tänzelndes Pferd
    Neither F1 engines nor engines in general were referred to as "power units" pre-2009, when F1 adopted KERS..
    Johnny_Bravo likes this.
  17. Enzo Belair
    1,591
    Texas
    Scott
    I didn't write it, my friend sent it to me. He is a mechanical engineer. He has been developing race engines going all the way back to when Honda built the Prelude 2.2 liter motor pushing 13K RPM and 450hp NA in 1993, that was his project. He has been in engine development his whole life, most recently consulting on hybrid systems for the best known Hypercars on the market today as well as hybrid systems for military drones. In his spare time he rebuilt both of my 1960 250 Colombo engines for my Ferrari's, he is everything engine from the early V12's all the way to the most current F80 setup.
    BTW if building a V12 was a better solution for the F80 Ferrari would have went this route. It was part of the "whitepaper" for the F80 project, and in the end they chose the direction they took for performance reasons, its non disputable.
  18. Gh21631
    Gh21631 F1 Veteran
    9,175
    East
    While I can make a case for the V12, that 6 cylinder platform is pretty darn good. If they can get the right sound out of it I am sure it will be great.
  19. Eilig
    Eilig F1 Rookie
    4,135
    Tänzelndes Pferd
    That was not written by a mechanical engineer. It was written by a marketing department. What other imaginary people inhabit the world in which you live?
  20. This poll is really asking whether you prefer performance (hybrid V6) or heritage (V12).
    And, no, we cannot have both.
    Unlike many things, these two choices are indeed mutually exclusive.
    willcrook likes this.
  21. Caeruleus11
    11,620
    why not?
    They now have a winning heritage with the V6turbo hybrid platform. The reason we all say V12 V12 V12 is because it won races for Ferrari. Many times it was not the most powerful but it was the most durable or reliable. The V12 happens to sound glorious, and it has other wonderful attributes. But if it didn’t sound amazing, we’d still find a way to say it sounds good, because it won. Anyway, we now have the heritage, the performance, the myth, which is the V12. And rightly so. Maybe it is a missed opportunity, they could have found a way to adapt the V12. But I will give them credit for taking an approach that is directly inspired by racing but also takes important understanding of road cars into consideration.
    I think the 296 sounds pretty good, so theres no mechanical reason why the F80 couldn’t sound better; but there are regulatory reasons. The F80 is pretty quiet, and thats a shame. Sound=energy; energy=emotion; and these cars are about emotion first and foremost. Maybe they can figure out a way to get more sound out of the car and still be in compliance with regulations?
    SPAVE, MDEL and day355 like this.
  22. Eilig
    Eilig F1 Rookie
    4,135
    Tänzelndes Pferd
    Agree. Differential spec for US vs non-US cars, as has been previously discussed for other models, would be a great first step.
    jumpinjohn, Boomhauer and Caeruleus11 like this.
  23. ab08
    ab08 Formula Junior
    Aug 28, 2007
    480
    #23 ab08, Jul 23, 2025 at 6:54 PM
    I disagree with the mantra that the V6 has more performance than the V12.
    It's worth remembering that the current V12 (F140) was launched 23 years ago (Enzo), while the F163 V6 was launched six years ago (296 GTB).
    It's very convenient and comfortable for some to claim that its new V6, suffocated with turbos and excessive electrification, has more performance than the V12 N/A projected 23 years ago.
    The V6 F163 is the highest performing engine not because it is a V6, but because it is the only engine developed in the last decade by Ferrari, combined with forced turbo induction and electrification.
    The question is: how would an all-new V12 Ferrari perform? I'm sure the V6 wouldn't even stand a chance.
    In my opinion, if a V12 competes on equal engineering and age conditions with a V6, the V12 will always win, as it has greater capacity. In fact, it would win in everything: performance, excitement, collectibility.
    It's also important to emphasize that, in today's engineering, there's little difference in weight between a V6 and a V12.
  24. Enzo Belair
    1,591
    Texas
    Scott
    He didn't write it, he sent it to me, and I'm guessing that comment is beneath you. And its origins does not demean its credibility or accuracy.
  25. day355
    day355 F1 Rookie
    Jun 25, 2006
    2,584
    If we analyze the situation, I would say we can have both, because on one hand, who can reasonably think that a LAF is underpowered and lacks performance??? We're talking about a road car, not a car intended to set lap times in a race!!! And on the other hand, if Ferrari had wanted to play "positively" with its difference, thanks to the aura of the badge, it would have focused on a significant reduction in weight, because less weight also means more performance. Finally, we're dealing with power figures on open roads that are totally unusable, except for flattering egos, because objectively, we are more in a contest of who has the biggest, rather than a more objective approach to automotive passion. We're talking about road cars, and 1300 hp on three-meter-wide ribbons in the middle of traffic is of no interest, let's wake up !!!
    Is this going to continue until where ??? soon or later 2000 hp for the road, and some will find that it is not performing well enough compared to the competition...come on ...
    Johnny_Bravo, ScrappyB, MDEL and 2 others like this.
