[Poll]: What viscosity oil are *you* using in your 308? | FerrariChat
Discussion in '308/328' started by Perfusion, Feb 21, 2006.
What weight oil are you using in your 308?
  1. 0W-40
  2. 5W-40
  3. 10W-40
  4. 15W-40
  5. 20W-50
  6. 10W-30
  7. 5W-30
  8. Other
Multiple votes are allowed.
Results are only viewable after voting.
  1. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    I tried to pick 8 "likely" poll choices. If yours is not on the list, please post it in this thread. I think it'd be nice to get a consensus of what the majority of folks are using, and with what year cars.
    If you vote, please reply to the thread and include how you voted and your year car. Thanks!
    Aaron
  2. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    I've got Mobil-1 0W-40 Synthetic in my '79 308GT4 right now, but I'm considering changing. My oil pressure is fairly low when the engine is hot, and I'd like to improve that condition.
  3. mark328
    mark328 Guest
    Jul 30, 2005
    664
    Mi
    Mark
    In my 328 I used Mobil 1 15w-50
  4. Rifledriver
    37,074
    A. What's low?
    B. Ferrari oil pressure gauges are notorious for being inaccurate esp at the low end of the scale.
    Also as long as it picks up right away with RPM it is ok to be pretty low at idle. 40W is really as high as you should need to go especially since we don't have an Autobahn.
  5. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    When the oil temp is to the right of 6 o'clock on the gauge, and PSI is at the "0" line, or just a *hair* above. When stone-cold in the morning, pressure is good - probably midway between 0 and 6 (so, 4) - and on the freeway it's fine...approx. 1 per 1000 RPM.
  6. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Oil varies and is dependant on ambient temps and what use the car will be subject to.
    Mobile 1 synth 5W-30 for early spring and late fall New England street driving.
    Mobile 1 synth 0W-40 for summer beater street driving.
    Was using 20W-50 Amsoil for track in 2005, but i may be changing to Red Line 30 weight or ??? Have not tested various oils to get a handle on what i will settle with for 2006 track season.
  7. racespecferrari
    racespecferrari F1 Veteran
    Jan 31, 2006
    7,583
    Suffolk, Uk
    Pete.G By The Sea
    I Use Castrol Rs Synthetic
  8. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    Mobil 1 15W-50 in the Southeast. Dual-purpose street and track.
  9. Rifledriver
    37,074
    Thats a classic sender problem but don't just assume it's OK. Get it checked with a mechanical gauge.
  10. wcelliot
    wcelliot Formula Junior
    May 7, 2004
    577
    Maryland, USA
    Bill
    The new Castrol fully synthetic 5W-50 in a '78 308. Great stuff that I'm now running in all my older cars that need a heavier oil.
    Bill
  11. ndnguyen
    ndnguyen Karting
    Jul 27, 2005
    166
  12. 308 GTB
    308 GTB F1 World Champ
    11,716
    New Jersey
    Barry Wolinsky
    Agip Sint 2000 10W-40 in my 1976 308 GTB year-round.
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    Thats what I use too. I'll add 20w50 if I can't find the castrol, but 5w50 castol is my first choice.
  14. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Castrol 5W-50 syntec. A while back this topic went around and around in Tech Q&A. The feeling of most of the experts was that Ferrari recommended 10W-50 for a reason and so the "50" part of that was important. The Castrol 5W-50 is the closest thing to it, and theoretically gives a little better wear protection when the engine is cold. Before that I used 10W-40.
    Birdman
  15. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    I've been using Castrol TWS 10w-60 in my Boxer for years and have been well pleased. It's hard to find anywhere but a BMW dealer.
  16. MDshore348
    MDshore348 Formula 3
    Dec 24, 2004
    2,460
    Maryland
    Darron
    15-50 mobil 1 -just found at walmart ...
  17. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,958
    MD and NE
    Robbie
    I also use 15w-50 in my 328. I didn't post in the poll because I don't own a 308!!!!!
  18. Gatorrari
    Gatorrari F1 World Champ
    16,455
    Georgia
    Jim Pernikoff
    Since the 328 engine is similar to the 308 QV, I guess I can respond: I use 15W-50 Mobil 1, though others say 10W-40 would work just as well.
  19. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    Well, crap...looks like I'm definitely in the minority with my 0W-40. I will say that I have a leak from (I believe) the area of the rear main seal that I didn't have before the change - scratch that...I did notice one tiny spot beforehand...but it's worse now - so perhaps I should switch to the Castrol 5W-50.
    A smart person would repair the damn leak, I know, and not worry about if it's the oil causing it or not....
  20. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    I've used Valvoline 20-50 for years on my '78 GTS. I was always unsure about going to synthetic because of the rumors that there would be more leaks. I used to just use dino oil but now I use the synthetic blend. Makes me feel better about not changing the oil every 3 or 6 months.
  21. 208 GT4
    208 GT4 Formula 3
    Dec 27, 2003
    1,769
    Brighton (UK)
    Dan
    I use 20w50 because my valve seals are past their best. And also it was the reccomended oil in 1975.
    But I believe you can get better protection from modern synthetics, which don't tend to come in 20w50 flavour.
  22. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    Castrol Magnatec Semi Synthetic 10W 40 in my 328.
    Considering going to Mobil 1 0W 40 at the next change.
    I.
  23. sguinn
    sguinn Karting
    Nov 12, 2005
    151
    Arkansas
    Spencer Guinn
    Mobil 1 15w/50 in my 79 308
  24. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    I also use Mobil one 15w50 in my 85 QV
  25. enjoythemusic
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Try it, should be fine. i use that for daily beater driving.
