Poor compression, high leak rate = bad valve guides? | Page 2 | FerrariChat
Discussion in '348/355' started by Dave rocks, Apr 15, 2016.
  1. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    I have the complete engine wiring harness out of this car and looked it over briefly. For a car that was very neglected, I can tell you I'm shocked how good the electrical pins look on this harness. At some point, I will test the integrity of the entire harness and only fix anything in need (aside from crumbled boots).
  2. f355spider
    f355spider F1 World Champ
    18,061
    #27 f355spider, Apr 16, 2016
    I will share a little story on my previous 1997 F355 spider I purchased in 2004 with 27k miles from FoS. Before buying the car, I reviewed all the service records and the dealer inspection report (as the car qualified for FNA's optional extended warranty program). The inspection performed three or four months prior, noted a couple cylinders with slightly lower compression (around 10 or 11% lower than the rest), and the leak down also showed higher numbers (I believe over 20%)
    The remedy they used was to use a product called "GM Top Cleaner" which they ran through the intake to clean out the intake deposits. In addition, the owner allowed the lead service tech to drive and use the car "spiritedly" over the weekend. The following week they did the tests over again, and compression was fine across all cylinders, and only one cylinder had leak down at 10%, the rest were all single digits. The report recommended the owner run the engine at higher revs than previously to prevent this from recurring. They also stated they believed the 10% leak down on one cylinder would continue to improve with "spirited" use.
    I ended up buying the car, owned it for 10 years, and had two major services performed at FoS and never had issues with compression or leakdown numbers (checked before and after each major). Sold the car with around 64k miles a couple years ago. :)
  3. f355spider
    18,061
    I also recall a tech session I attended years ago, and Nick Scianna of Nick's Forza Ferrari also mentioned they saw a number of F355s with intake deposits. He recommended that F355 owners occasionally use Lubro Moly Ventil Sauber (now called Liqui Moly Valve Cleaner), added to their gas every 2,000 or 3,000 miles.
  4. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    WOW!!!
    Great videos, and great thread! Thanks for sharing.
  5. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    SoCal LA/OC/New Mexico
    Tim Dee
    yes great stuff for sure!!! I have a few bottles here
    I have a pressure cleaner for the top end also just need to make adapters for the 355-348
  6. Rifledriver
    37,373
    Anyone with any degree of ability and any degree of experience with 355s would have never diagnosed that car or even suspected that car as having bad valve guides.
    A. They never go bad at the same rate. #2 and sometimes #7 always go bad first. So much so that typically the others will have new or near new compression numbers.
    B. Problems with carbon build up is well known within the professional arena. It may not be here but you tell us nothing new.
    c. Not measuring wear? WTF does that?
    Your assertion that they are often misdiagnosed is not true if applied to us. It might be true among the various keyboard warriors that regularly offer advice on the internet.
  7. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I can't comment on your work or experience because I don't know you. And, for the record, I'm not doubting it.
    But, I know that much more than "keyboard warriors" would have and have jumped to replace guides based on the compression and leakdown as posted above. We can agree to disagree but their is no doubt that 355 valve guide jobs have been done when they were not needed, by techs and shops of all levels.
  8. Jackie and bill
    Jackie and bill Formula Junior
    Nov 29, 2014
    795
    GB
    William
    I for one would like to thank the likes of you stepping up and posting what you find and what you are doing in threads like this. Many dont in fear of being picked apart.
    The majority of what people learn and do is through people like yourself, god knows they learn nothing from the so called experts apart from the odd quip.
    Kind of reminds me of a chap on here many years ago called RF. He wrote the first how to remove the 355 engine from the car, not an expert but a home diyer. His how to was the seed that today has grown into a situation that now many remove there own engines for cambelt changes.
    Thanks Dave
  9. ernie
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    Though you'll never get them to admit that.
    GTUnit likes this.
  10. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,300
    CT
    John Kreskovsky
    Yes, on a solid tappet you need to have the lash set correctly. But on a hydraulic tappet the tappet is always in contact wit the cam so the timing would be correct, geometry wise, but if the lifter collapses more than it should then the valve will open late and close early.
  11. driveitdaily
    driveitdaily Formula 3
    Jul 20, 2013
    1,041
    lake ariel pennsylva
    john
    #36 driveitdaily, Apr 16, 2016
    I'd be looking for the cause of the excessive carbon buildup , an engine running properly , with a correct fuel air ratio should not be producing enough carbon to build up like that . This would go back to what fbb pointed out , something like bad connections could be the culprit , engines dont just carbon up , there is something causing it. Where it is wet in some of those pics , i'd figure that carbon could be caused by oil comsumption , possibly entering the combustion chamber and being burned leaving the deposits , thru bad balve guide seals or the guides themselves. An old car with a carb could have mixture problems , but a modern fuel injected car should run clean enough to not leave that type of carbon deposit
    If it were mine , i'd be looking into some data to see what kind of air fuel ratio it was running
  12. johnk...
    Jun 11, 2004
    11,300
    CT
    John Kreskovsky
    #37 johnk..., Apr 16, 2016
    I would counter that by sighting old BMWs form the later 80, early 90 with were notorious for carboning up. BMW used to recommend adding Techron to every tank of gas. Pulling the head and blasting them with walnut shells was the alternative. Apparently there is still a problem with the N54 engine.
  13. plugzit
    plugzit F1 Veteran
    7,816
    Redondo Beach, CA
    Bruce Bogart
    IIRC, that was a problem with the secondary air system with ports in the head rather than the exhaust manifold.
  14. Markphd
    Markphd Formula Junior
    Mar 10, 2012
    713
    Although I didn't personally measure them, I had plenty of evidence that at a minimum the valve seals were bad, and my machinist measured them (told me the numbers which I promptly forgot and replaced the guides which were pretty bad on #2 in particular. The others weren't as bad, but since I was in there I just had them all replaced.
    That nasty picture above looked like my #2 cylinder, which was eating oil... never a good sign for the valve seals/guides. Sorry about your luck... I don't have much to add with regard to the troubleshooting at the moment, the stooges covered the obvious and not so obvious.
  15. fatbillybob
    Aug 10, 2002
    29,470
    socal
    Yes and that's the wrong timing and there is no way to know if the lifter has collapsed.
  16. fatbillybob
    Aug 10, 2002
    29,470
    socal
    The N54 is a direct injection motor a totally different animal than a fuel injected motor. All manufacturers are having a problem with intake carbon on DI motors. The solution is simple.
    On Ferraris there is also a general over fill of the oil that gets sucked into the intake. Everyone wants to run their oil level right to the max line as if more was better.
    GTUnit likes this.
  17. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,704
    San Carlos, CA
    Mitchell Le
    I would never conclude that all guides were bad on the same side. And I don't run away from high leak down. I would just drive it more aggressively.
  18. fatbillybob
    Aug 10, 2002
    29,470
    socal
    #43 fatbillybob, Apr 16, 2016
    The additives are nice but to work well I have had to use more that they say and it ain't cheap nor does it do as well as walnut shells. Walnut shelling is cheaper and faster and cleaner IMO. Here is a before and after on a maranello. I don't think you can come close to that with chemicals. Each port took about 10 seconds to clean and 10 seconds to suck out the shells. Tools are shop vac, blaster head, and walnut shells.
  19. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    The point to the additives is to prevent / remove build up in a car that is operational. Tearing the motor aparts and cleaning the heads is an entirely different topic and process not related to keeping the motor clean...
  20. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    PS, if I am seeing that correct, you blasted with the heads on the block? If that is true, I would never do that as the blasted walnut shells will pulverize and you won't get all the dust out.
    But, that's me :)
  21. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    That's why you use walnut shells. Even if there are bits leftover they won't hurt the engine. The BMW factory specified procedure for addressing the valve deposits caused by bad gasoline back in the '90s used walnut shells on an attached head. I'd be more concerned about excessive use of fuel additives.
  22. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Carl and Mike, my apologies. I'm in shock about this technique.
    I also happen to own a 2008 BMW 335 xi with 123k miles, bought new and this process has never been done.
    http://youtu.be/NnMhNXXawjk
    I guess we now need port adapters for Ferrari motors.
    Also, this technique does not address the sealing surface of valve and seat so fuel additives would still be beneficial.
    Crap, I guess I now need a walnut blaster :)
  23. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    Tim Dee
    You need to use Nut oil as a lubricant
    GTUnit likes this.
  24. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    Tim Dee
    This is why you do this, works amazingly well. I have one of these since the late 70's and still is the system
    [ame]http://www.youtube.com/watch?v=wOVXPQLTbgo[/ame]
  25. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    No worries, Dave. That's the great thing about forums such as this-- we can all learn something from one another. I've learned way more here than I've contributed, and I'm kinda-sorta in the biz.
    I've seen issues very similar to the ones depicted in your OP in a 348, which were attributed to bad gas by my machine shop that did the work on the heads. In the specific case cited, I wonder if the car had been run a bunch without ever coming to full operating temp and getting properly "aired out".
    My edict is to pay *very* close attention to the type of fuel being run (Shell ONLY, because I have firsthand experience of its superiority) and to make sure to run the car to full operating temp pretty much every time you start it. The worst thing you can do to a performance engine is to start it and shut it down shortly thereafter. As the owner of a track prep shop, this is an ongoing issue for me. We push more cars around the shop than we drive. The term "Italian Tuneup" exists for a reason, but very often the owners of pristine cars never run them that hard.
