Pop up lights | FerrariChat
Pop up lights
Discussion in 'Technical Q&A' started by Lino, Oct 2, 2012.
  1. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Hi,
    i was hoping that maybe someone can help me with this, I have a 89 Mondial T. When i turn on the lights the actual lights dont pop up. i can see the lights on through the space but it sometimes takes 10 minutes for them to go up.
    lino
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    They are operated by a pair of motors quite similar to the window motors. If both are equally the problem I suspect trouble at the switch or a relay. Check connections (particularly ground wires).
  3. WATSON
    23,879
    WI
    ....what Tim said.... he knows. But see if there is a relay in wiring system that has died as well.
  4. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    I was suspecting the relay, but I will look at the grounds.
    Thanks I will keep you posted.
  5. Motob
    Motob Formula 3
    Nov 11, 2003
    2,387
    Frederick, Maryland
    Brian Brown
    There are two separate relays/fuses and motors for each headlight. If neither headlight motor works, then I would suspect something that is common to both circuits, such as the headlight switch.
  6. mg54
    mg54 Rookie
    Jan 12, 2005
    48
    Massachusetts
    Michael Gardner
    Definitley check the switch...my 85 QV had a similar problem. The cap at the end of the handle pops off...There are 2 wires inside that may need to be re-soldered. Be careful when you pop it off. There is a small ball bearing that seats it. Took a few minutes to fix. Verell showed me how to do it.
  7. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    i will check that this evening. it must be the switch since as mentioned they both dont come out.
    thanks
  8. Steve Magnusson
    26,931
    #8 Steve Magnusson, Oct 3, 2012
    Another indication would be that if the exterior parking lights and dash lights don't come "on" when you rotate the knob = almost certainly bad knob switch (but could be the ...006 relay that the switch closes to turn on the parking lights). However, the converse is true too -- if exterior parking lights and dash lights do come "on" when you rotate the knob = not a bad knob switch (and the ...006 relay is the next downstream suspect).
  9. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Hi Steve,
    Yes the dash lights and park lights are on and so are the headlights but the lights don't pop up, so if its not the wires you say it's the relay (006)... Is hat right?
  10. Steve Magnusson
    26,931
    Unfortunately, I don't have a Mondial t wiring diagram, but based on the information in your 553/89 OM, I'd try (in this order):
    0. Check that fuse #1 (25A) is OK (do your engine bonnet opening mechaism and fuel filler mechanism work?).
    1. a different ...101 relay for relay T (relay for headlamp motor with dipped beam)
    2. a different ...101 relay for relay D (relay for headlamp motors)
    3. a different ...006 relay for relay O (relay for external lights)
  11. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    I got in late the only thing I tried was to remove the rubber part at the end of the steering wheel switch, no cap for the t. Maybe it's different on QV. I didn't see any wires, maybe in steering column.
    Steve II did a few cycles and it worked but then sometimes it didn't work. Could this still be a relay?
  12. Steve Magnusson
    26,931
    #12 Steve Magnusson, Oct 3, 2012
    Definitely still a possiblity (but intermittently working does rule out a blown fuse #1 as the problem).
    (Don't worry about the knob switch -- if the exterior parking lights and the dash lights come "on" and stay "on", the knob switch is working fine.)
  13. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Ok now the dumb question, how might I go about testing the relay and if its no good can we get these relays?
  14. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    #14 finnerty, Oct 4, 2012
    Easiest way is just to swap in another relay. Some of these units can be not so cheap (even tough to find quickly), so if you don't want to buy a new one --- certainly a waste of money if it turns out not to be the problem --- use an identical relay (look for matching p/n's) from another circuit on the car.
    Obviously, you want to select a relay from a circuit / system which you know to be in good working order (so you confirmed that relay is also "good"), and a system that is not critical to anything the car needs when the ignition key is switched "on".
    As Tim said, the HL lift motors are similar to the window regulator motors --- so, I would have a look at those relays (for the window motors) first to see whether they are a part number match. Part numbers are embossed / stenciled on the exterior of the cases of the relays.
  15. Frari
    Frari Formula 3
    Nov 5, 2003
    1,194
    brisbane australia
    tony
    I had a problem with my 355 where one light would work and the other did not, it turned out to be wear in the motor so I had the motor pulled apart and re copper wired and re sealed in a wax type of sealant. I worked fine after that so if all the above fails it may be the motor as if i turned the round knob on top of the headlight motor it worked fine but if I used the stalk it did not. It was something to do with constant stopping in the same place in the wire loom.
