Porsche 996 C4S- tires question | FerrariChat
Discussion in 'New York Tri-State' started by niptuck, Jun 20, 2006.
  1. niptuck
    niptuck F1 Rookie
    Mar 1, 2006
    2,581
    NYC, NY
    John L.
    Hey all,
    My brother's back tire recently deflated to 10psi [normal= 44psi] because of a nail and a bolt sized screw. The tire was plugged by a repair shop...but Porsche dealership claims that for high speeds he will need to replace the tire- actually both back tires in order for the tread to be equivalent.
    Any thoughts?
    Do both tires have to be replaced even if the the pressure is currently maintaining itself just fine?
    Is it unsafe to be driving on...say..a FUN RUN...with a plugged tire???
    Thanks in advance!
  2. Sharif
    Sharif Formula Junior
    Oct 19, 2003
    303
    New York
    Sharif
    just to be on the safe side I would get them patched. Plugging is from the outside and patching is when they take the tire off the rim and repair it.
    Patching is a lot safer.
  3. Sharif
    Oct 19, 2003
    303
    New York
    Sharif
  4. jet190rs
    jet190rs Karting
    Jun 21, 2005
    208
    NYC
    Rich C.
    i've had my one of 545i's runflats plugged/patched from the inside, and i hit 130 on it. replacing the tires is ideal though.
  5. DodgeViper01
    DodgeViper01 F1 Veteran
    Oct 1, 2003
    6,867
    To be safe, replace both rears. If you have a tire at 100% and one at 50% thread life, you can feel the difference and it can cause problems at high speeds. Also make sure you go with the same brand and tire all around. Different brands at the same time can also cause problems.
  6. niptuck
    niptuck F1 Rookie
    Mar 1, 2006
    2,581
    NYC, NY
    John L.
    Sharif, Keith, and Rich- Thanks.
    If it makes any difference...he has Z-rated tires, 18 inch..perhaps further reason to replace both tires.
  7. DodgeViper01
    Oct 1, 2003
    6,867
  8. ghost
    ghost F1 World Champ
    Dec 10, 2003
    10,046
    Singapore
    No question, replace both. Preferably with same manufacturer as on fronts. If treads on front are < 70%, I'd replace all four. As they say..."there's just too much riding on them." - :)
  9. Parikh1234
    Parikh1234 F1 Rookie
    4,726
    Little Ferry, NJ USA
    Shivam Parikh
    when replacing any tire I always replace all 4. If you are on a track or something it will make a world of difference. If they are within 2-3k miles of each other then its ok.
    As for the hole, def replace the tire. Never go high speeds on a tire that is even slightly damaged. I check my tires for damage every morning. Probably cause there isnt a day when I dont hit 100 mph.
  10. Greg G
    Greg G F1 Rookie
    John... I see a whole lot of subjective replies to your question... The fact is, if the tire is fairly new, and has most of its tread... having it patched from the inside shld be absolutely safe for normal and fun run driving.
    Now if the tread wear is significantly less, then that wld justify replacement, and replacement can be done minimally in pairs. Of course if all tires are well worn, then smart money is to yank em all.
  11. jhsalah
    jhsalah Formula 3
    2,409
    Philadelphia, PA
    Jawad
    i gotta go with Ghost on this one... Manny just had a new kid... SOOOOO much riding on those tires. Be safe out there...
  12. Parikh1234
    4,726
    Shivam Parikh
    2nd. A new set of tires will run you maybe 1200 bucks. Just replace em. Not worth the risk. What they tell us at here is that your tires are the only saftey feature you have that is actually touching the road. No matter what systems or driving skill you have, if your tires go, you are screwed.
  13. niptuck
    niptuck F1 Rookie
    Mar 1, 2006
    2,581
    NYC, NY
    John L.
    Vik, Shivam, Greg, and Jawad- Thanks.
    It looks like he will not only replace both back tires, but also lower the car with H&R suspension (as per Vik's suggestion), and get black/silver rims. :)
  14. jhsalah
    jhsalah Formula 3
    2,409
    Philadelphia, PA
    Jawad
    That car will look sweet (or even sweeter). Look forward to seeing it.
  15. DodgeViper01
    Oct 1, 2003
    6,867
    Can not wait to see that in person.
  16. ghost
    Dec 10, 2003
    10,046
    Singapore
    Sweet! Car looks much better lowered. Can't wait to see.
  17. JustinS
    JustinS Formula Junior
    Aug 11, 2005
    305
    Justin S
    Replace it or both depending on mileage.
  18. rpps
    rpps Formula 3
    Aug 20, 2005
    1,828
    Bergen County, NJ
    Richard
    ah!
    i just had a flat this weekend :( had someone plug it, but now i am nervous. now that i read about a blowout...i will get a patch right away!
    the problem in this whole situation: i just got 4 brand new tires this past wednesday! $1200 down the drain. sat-front pass side tire dead.
  19. jhsalah
    jhsalah Formula 3
    2,409
    Philadelphia, PA
    Jawad
    When you got your new tires, did you have a warranty?? You should really check. I put 4 new ones on my 308 a couple months back and for an extra $30 or so per tire got a one or two year warranty (don't have the papers in front of me) that covers even blowouts (in the ordinary course). WELL worth the extra $120.
    Good luck, and sorry about your flat.
    Drive safe.
  20. rpps
    rpps Formula 3
    Aug 20, 2005
    1,828
    Bergen County, NJ
    Richard
    i got the tires through my vw dealer. they did not offer a warranty or anything of that nature, so im pretty much screwed.
    i am definately going to have the tire inspected and patched from the inside as you guys suggested.
    drive safe as well!
  21. Harmonyautosport
    Harmonyautosport Formula Junior
    Apr 28, 2006
    683
    New York
    Its cheap insurance why risk it. On a daily driver that you dont speed around in much its not a problem but for a weekend toy why risk it.
  22. ghost
    Dec 10, 2003
    10,046
    Singapore
    Good advice, from a professional.
  23. Griza
    Griza Rookie
    May 21, 2005
    37
    Somers, NY
    G. Findlay
    If he is doing the suspension he should go with PSS9's. Much better than H&R and I am a fan of H&R. PSS9's without question........
  24. Arrwin
    Arrwin Formula Junior
    Sep 14, 2004
    537
    Midtown NY
    Arrwin
    Yes. PSS9s are what I have, but it may be overkill for reg. driving. They are a coilover system, so you can set it to be more/less firm.
  25. Griza
    Griza Rookie
    May 21, 2005
    37
    Somers, NY
    G. Findlay
    I have them on my 996tt and think they are great for street driving. They could be overkill though if you are just looking for a drop. I guess I feel like if you are going to spends money, might as well do it the right way the first time!!
