PORSCHE EXPERTS | FerrariChat
PORSCHE EXPERTS
Discussion in 'Porsche' started by veet, Feb 2, 2012.
  1. veet
    veet Karting
    Nov 4, 2010
    96
    Sudbury ON
    Vito L
    Thinking of trading one of my cars for a 1987 porsche 911 with 87000 Kilometers. The owner says it uses some oil which is "normal" .If so what is a acceptable amount it will use?Or not use anything? thanks
  2. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,762
    US of A
    Michael
    Hard to believe, but Porsche finds nearly excessive oil consumption somewhat acceptable. I understand that 600 miles per quart is not out of range for similar models. These are mechanical machines, some oil usage is to be expected after-all.
    I would not shy too far away from a Porsche that consumes a quart per thousand.
  3. Kds
    Kds F1 World Champ
    +1.........
    A litre per 1,500 KM is normal........so a quart per 1,000 miles is the same.
  4. Tcar
    Tcar F1 Rookie
    Make sure you have a Porsche Mechanic go over the car BEFORE you buy it.
    The 3.2 Carrera is a great car, but the engine did have some issues.
    That's what, less than 60k miles on a 25 year old car... low mileage, not even 3k mi/year.
    Sometimes a car that has been 'sitting' without being driven for long periods of time will leak and use more oil than one that's been driven regularly.
  5. ktr6
    ktr6 Formula Junior
    Mar 25, 2011
    947
    Knoxville, TN
    Keith
    My 87 was one of my favorite cars.....ever. Oil consumption is normal but I would encourage a PPI with compression/leak down prior to purchase.
  6. jmuriz
    jmuriz Formula Junior
    Dec 9, 2003
    395
    Arlington, VA
    The old saying is that if your Porsche doesn't leak oil...it's empty.
    Get a PPI and you should be OK.
    Heck, I have a 2.7 on an engine stand and it leaks w/o being hooked up to anything, go figure.
  7. MD911
    MD911 Formula Junior
    Sep 27, 2007
    331
    Hahaha. Or if it doesn't leak now, it will.
  8. MHK69
    MHK69 Karting
    Mar 14, 2009
    153
    San Jose, CA
    Matt K
    1000 miles per qt is acceptable oil consumption.
    But being a late 80's model I'd find out if the valve guides have been replaced. The worse they become the worse the oil consumption becomes. Nearly everyone I know who has a 911 of this vintage, myself included, has ended up doing a top end rebuild. The valve guides seem to wear around the 80k mile range, a similar story to the Mercedes 560sl. The replacements are made from a much improved material and once replaced will last a considerably longer time.
    So that's what I'd be checking, because it's not a case of if, but rather when they will need replacing. Figure a bill of around 6-7.5k to do the job.
    Matt
