Porsche-Oil Question .. | FerrariChat
Discussion in 'Porsche' started by amenasce, Nov 19, 2006.
  1. amenasce
    34,457
    Joe Mansion
    #1 amenasce, Nov 19, 2006
    As i was refuelling the 997 today, it asked me to put oil as the level was low.
    I put 2 liters and the level is still low as seen here in the pic . Pb is, Shell didnt have the Oil recommended by the owners manual , i had to put in 5W40..
    The Oil tank capacity is 8.25 Liter ..Is there any danger to drive it until i find proper oil ? And what can cause this, as i dont think 2 liters is minimum level..
    There is no way to check the level manually too !???
  2. Rexcoltrain
    Rexcoltrain Formula Junior
    Nov 6, 2003
    671
    Oahu, Hawaii
    My Boxster always said it was low when I would fill up. If your garage is level, put your key in and check the reading without starting. If it is still low you're OK to drive for a bit.
  3. brokenarrow
    brokenarrow F1 Rookie
    Sep 25, 2006
    3,737
    Txass
    Bill
    I recognize your guages as a 997, I believe. I have a 997S and loooove the car. Anyway, don't jack around get oil in the car and fast. Walmart carries the required oil as does Autozone. Continue adding a quart at a time as you get readings between each quart. Yes, put a quart in and take a reading. Put anoter quart in, etc. You want to have it with no more than one bar empty. USE THE REQUIRED OIL as stated in your owners manual. I use Mobil 1 5-40 synthetic. Let me know if you have any more questions.
  4. amenasce
    34,457
    Joe Mansion
    I had to put Mobil ! 5 30 as the Mobil station didnt have either 40 or 50 and i didnt know where to go to get them ( im new in town ).
    Do you any other places where i can get this oil ? I did Shell, Mobil and other stations and they didnt have the oil Porsche recommend.
    Also, there is no way to check the oil manually correct ? You have to use the online comp ? It made me wait 10 mns, twice to get the reading..
  5. Adrift
    Adrift Formula Junior
    Aug 30, 2004
    749
    Dallas area
    Oil changing places might have it, especially if you can find a Mobil oil changing station. Also Autozone.
    I haven't been able to find the 10w-40 at all, although the dealers around here certainly have it. I still use 15w-50, which is what came in my car originally; but it doesn't get as cold here in Texas as other places. Walmart sometimes has 15w-50.
  6. Kds
    Kds F1 World Champ
    Andrew.....
    Looks like you have 3,450 miles on the odometer in the pic.....therefore being down 2-3 litres is on par with the mileage driven.......they use about a quart every 1,000 miles......it is normal.......is that what you meant by what could cause this ?
    Also, when checking the oil level......was the engine at normal operating temperature, and were you parked on level ground ? Overfilling these cars can cause an expensive repairs.
  7. Adrift
    Aug 30, 2004
    749
    Dallas area
    A quart every 1000 miles is normal on a 997? Wow, 986 Boxsters are known for using virtually no oil. That sounds like a lot. My 996TT used oil at a little bit faster than that rate, but turbos are known for drinking the oil.
  8. amenasce
    34,457
    Joe Mansion
    I checked so many times..and in so many different places, i was really worried as the last segment was blincking even after i put 1 liter.
    My dealer called me back and said i should be fine with what i put.
    I check with the car at running temp ( the light came on as i was refuelling adter a 12 miles drive so the car was at 200 temp) and parked on level ground.
    All in all i put 2 liters yesterday and today , it showed 3/4 full ...
    Thanks for all the help :) !!
  9. amenasce
    34,457
    Joe Mansion
    Thanks ! Will look for autozone around here.
