Porsche Turbo Questions | Page 2 | FerrariChat
Discussion in 'Porsche' started by mikesufka, Feb 28, 2010.
  1. Kds
    Kds F1 World Champ
    Different F+R sizes on both the 348 and 996......IIRC "staggered ??" is the term tire guys use.
  2. mdoan300
    mdoan300 Karting
    Nov 14, 2003
    231
    North Texas
    Michael
    #27 mdoan300, Mar 2, 2010
    996 Turbo was available from 2001-2005 and 997 Turbo was available from 2007-2010. If you can afford a 997 Turbo, then you might also want to consider a 996 GT2.
    996 has 415hp/415tq (444hp/457tq for X50), 997 has 480hp
    997 has variable vane turbos that decreases turbo lag
    996 has 18" wheels, 997 has 19" bling, er, wheels
    In 2001, Turbo was available; some Turbos had front bumper warts; some Turbos had hollow-spoke wheels
    In 2002, a passenger-side glovebox was added; X50 and PCCB was offered as options
    In 2003, Porsche switched to MOST for the radio interface so it has a difference head unit, CDR-23 vs CDR-220 (makes it hard to go aftermarket audio w/ MOST)
    In 2004, Porsche started using the "Spanish" crankcase, crankcases manufactured at the Spanish factory; if memory serves me right, these crankcases are webbed and stronger (not that the other crankcases aren't strong)
    In 2005, the only Turbo available is the Turbo S, which has PCCB and X50 standard, but also includes wheels painted in GT Silver Metallic
    Beyond that, both (except for 2010 Turbo) are based off the "tried'n'true" M64/GT1 Metzger engine block -- pretty much an aircooled engine w/ water jackets added and water-cooled heads.
    Like other high-end cars, I would not shop merely by price and mileage, I would also pay attention to the options like supple leather, heated seats, colored gauge faces, carbon fiber trim, aluminum trim, etc. Under the hood, there is a sticker that has all of the option codes... if you can get the option codes, then you can decode what options a Porsche came with (and what was added later in aftermarket).
    Oh yeah... 996 stock boost is around 0.7bar and around 0.9bar for X50; if you're seeing 1.0+bar on a 996 Turbo, then chances are it has ECU software. I don't know what the factory boost is for the 997, my guess is 0.9-1.0bar.
    996/997 engines are reliable, but not as solid at the TT/GT2/GT3. Some 996 will develop rear main seal leaks and failing intermediate shaft. The risk of leaking RMS for 997 is lower, but still remains; HOWEVER, I have not read anything about IMS failure on the 997 so that is very good.
    This changed in 2009 when Porsche released a new DFI engine w/ fewer moving parts and no IMS (so no risk of IMS failure). If I were getting a 997, then I would opt for a 2009, but there is no long-term reliability data available. The 2009 3.8 S models have 385hp, as much as a 996 GT3! I test drove a 2009 C4S w/ PDK; with launch control (there were 2 launch control settings, IIRC), it felt like God himself picked you up and just threw you.
    ///Michael
  3. UroTrash
    Jan 20, 2004
    40,727
    Purgatory
    Clifford Gunboat
    Well, there we go.
    348 requires 4 differnt wheels.
    Somehow the Italians can keep it straight but the Germans use the same solution as Dodge does on the Neon? Pathetic.
  4. mikesufka
    mikesufka F1 Veteran
    7,922
    Crosslake, MN
    Mike Sufka
    Great post. Thank you!
  5. mikesufka
    7,922
    Crosslake, MN
    Mike Sufka
    I have a few reasons for the Turbo. First, the Turbo has been one of the cars I've drooled over since I began reading Car & Driver in grade school. Second, after owning a 2001 Viper RT/10, I don't want to be disappointed with HP or lack thereof. Third, knowing "there is a Turbo", I don't know if I'd be happy with the lesser version.
    This purchase probably won't happen overly soon. But, I have a new "want", so it's time to get educated.
  6. ferraripete
    ferraripete F1 World Champ
    nuff said...a turbo it must be! you will not be disappointed.
  7. Doug
    Doug Formula 3
    Nov 13, 2003
    1,473
    Louisville KY
    Doug
    Also, if it takes a dealer 10 years to figure it out, 99% of the buyers out there will never notice it:)
  8. Kds
    Kds F1 World Champ
    #33 Kds, Mar 3, 2010
    True 'dat........LOL !!
  9. LightGuy
    LightGuy Four Time F1 World Champ
    Oct 4, 2004
    46,160
    Texas
    David
    996TT's are known to be bulletproof.
    Stock engine internals are said to be good for 700HP. Its GT1 stock block for a grand.
    A great car for the money.
    10 or 20k more miles for $10K less is a good trade.
    I would not get a tip as they are quite a bit slower.
  10. BOOMER7
    BOOMER7 Karting
    Jan 3, 2009
    146
    2005 had both regular Turbos and Turbo S. Lot's of guys try and pass off fake S cars but only the real ones have the ceramic brakes (Yellow calipers). I looked at 10-15 cars before buying. Be careful if you decide for a RARE car in the 2005 TURBO S
  11. jet
    jet Formula Junior
    Apr 12, 2004
    837
    Bay Area
    + 1 except that tip is not "quite a bit slower"..the difference is .1 of a second as I recall.
  12. Carnut
    Carnut F1 Rookie
    Nov 3, 2003
    3,797
    Gladwyne PA
    Morrie
    I owned 2 of the 996 versions, both tuned and both turned into RWD, they were alot of fun, and one used to go from nothing to 1.2 boost, that one you needed to make sure you were pointed in the right direction on. Just remember one thing turbo, non turbo, something new, faster, and better will always be coming. After 39 Porsches the one that ended up being a keeper was not a turbo.
  13. ferraripete
    yes but old turbo never die...the simpy go back to the shop for even more hp!!!
    lol...i think you know that as well as i!!
