Portofino Launch and picture thread | Page 25 | FerrariChat
Discussion in 'California(Portofino)/Roma(Amalfi)' started by Traveller, Sep 4, 2017.
  1. inox
    inox Formula Junior
    Oct 11, 2017
    628
    1) Besides the nose section, also the rear corner body panels are probably made from plastic. I think it is a common practice in all cars. California owners could confirm this is the case with Ferraris too.
    2) The air outlet below the body panel is an elegant solution. Its purpose is partially same as with front wheel arch air exits. To unpressurize the rear wheel arches. Visually it gives an impression double diffuser (a design concept from recent Formula 1 history) and theoretically also works as such, although the effect is marginal.
    crinoid and manya81 like this.
  2. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    #602 4th_gear, Dec 29, 2017
    No, I'm pretty sure #1 is aluminium.
    Think of it this way - we all know painted metal looks very different from painted plastic - so Ferrari would not use a different material on the rear quarters. It would look horrible. From what I have seen, Ferrari also appears to be heavily invested into aluminium fabrication. It is a core competence. The accurate shaping and fitting of aluminium panels can be fine-tuned in the later stages of hand assembly (watch a Ferrari factory video), aluminium is also repairable, plastic cannot be fiddled with. I also don't think there's much difference in cost between panels made from either material.
    #2 does look interesting and here's a better view of it. It may indeed depressurize the rear wheel arch or... it may simply allow air and more exhaust sound from the muffler body to come through from the undercarriage. This would improve traction as well as the "noise". Unless this is already described somewhere we would have to wait until someone has some definitive information on it.
  3. TheMayor
    107,807
    Vegas baby
    Area 1 and 2 are plastic. No question. I don't think it's a cost reduction issue. It's a collision replacement issue and perhaps current safety regulations.
    LARRYH likes this.
  4. XDINO
    XDINO Karting
    Feb 20, 2008
    103
    Chicago / Naples
    Rich
    Yes area 1 would have to be flexible plastic bumper material. Otherwise there would not be that diagonal seam from taillight to wheel opening. But area 2 does appear to be expanded metal mesh for ventilation, not a textured plastic piece.
    LARRYH likes this.
  5. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    OK guys, it's freezing in my garage but I popped in and lifted the car cover to check area #1 and it does feel more like plastic than aluminium when I pat it. :rolleyes: FWIW, the paintwork is very very close but does look faintly different from the panel further forward which feel more rigid when I pat it. My bad.
    Area #2 on the PF, from the photos, looks just like a meshed vent or outlet as inox pointed out.
  6. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    Here's another thought on Area #1.
    It may also be a service issue because when I had some Capristo exhaust system and diffuser upgrades done on my Cali30, both sides of the Area#1 along with the rear bumper had to be removed as a complete single assembly. If it were aluminium, the panels would be very delicate to handle, heavier and more complicated to take off and re-install.
    I imagine minor rear end mishaps are also pretty common so using plastic rear panels would lower the cost of service, just like the front bumper which is definitely plastic.
    inox likes this.
  7. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,554
    Bournemouth, UK
    Plastic in these places is a good thing! Makes the car lighter and absorbs small bumps better.
  8. GlowRed
    GlowRed Formula Junior
    Mar 2, 2012
    259
    West Midlands, UK
    Front splitter is plastic - can be optioned in carbon
    Front wheel air vents are plastic - can be optioned in carbon
    Side skirts are plastic - can be optioned in carbon
    Rear vents by lights are plastic - can be optioned in carbon
    Rear bumper is plastic
    The online configurator does not show all the carbon options.
    andruslik and inox like this.
  9. bpolsky
    bpolsky Rookie
    Nov 4, 2017
    27
    Is this build slot still available? Tried to PM.
  10. Risktaker
    Risktaker Karting
    Feb 15, 2014
    102
    Does anyone know if the Portofino can be ordered with
  11. Risktaker
    Risktaker Karting
    Feb 15, 2014
    102
    Does anyone know if the Portofino can be ordered with Heated and Cooled seats ?
  12. OldDog
    OldDog Karting
    Nov 2, 2017
    55
    Sarasota, FL
    JJ
    As of Nov. 30, the only seat option is for "Full-electric seats". In addition to the standard 8 way electric this option gives some additional adjustments, an electric steering wheel column adjustment, a driver side memory, and a "Heat function". No cooling is offered and no "design options" (although the latter is alluded to). Clearly there is more to come, but for now that is what is offered.
  13. TSOYBELIS
    TSOYBELIS F1 World Champ
    Nov 30, 2005
    11,739
    Athens, Greece
    SPYROS
  14. geertf60
    geertf60 Karting
    Nov 24, 2003
    75
    hamme - belgium
  15. uhn2000
    uhn2000 Formula 3
    Oct 15, 2011
    2,128
    Toronto
    Joe
  16. TSOYBELIS
    Nov 30, 2005
    11,739
    Athens, Greece
    SPYROS
    +1
    Although I 'm not a fan of dual tone color
  17. RCorsa
    RCorsa Formula 3
    2,131
    West Coast
  18. XDINO
    XDINO Karting
    Feb 20, 2008
    103
    Chicago / Naples
    Rich
    Finally the USA Portofino configurator is working!
  19. F2003-GA
    F2003-GA F1 World Champ
    13,418
    Sunbelt
    Bro
    Is the rear bumper offered in Carbon If so anyone have pics ?
  20. andruslik
    andruslik Rookie
    Aug 13, 2016
    2
    Moscow
    Andrey
    No, carbon inserts around rear lights only
    uhn2000, Caeruleus11 and F2003-GA like this.
  21. Traveller
    Traveller F1 Veteran
    Apr 10, 2009
    6,323
    Tim
    Anyone have any idea on first reviews and deliveries?
  22. Avia11
    Avia11 Formula Junior
    878
    San Diego, CA
    My west coast dealer told me that orders for their first portofino demo in the next month and delivery of their demo in May/June...
    uhn2000 likes this.
  23. JimmyChooToo
    JimmyChooToo Karting
    Aug 7, 2017
    51
    Is Ferrari dropping the F1 Fog/Rain light as a design touch?? I noticed both the new Portofino and 812 do not appear to have it. So right now only the 488 GTB & Spider, F12 & F12 Tdf ever got the F1 Fog. Too bad, I thought it was a nice F1 touch.
  24. Raydog9379
    Raydog9379 Karting
    Jan 10, 2018
    131
    Ray
    Was in (Spezzano) next to Maranello staying with friends in Mid to Late December. There were cars like this all over the place just before Christmas in and around Maranello, Sassuolo, etc.. I was driving in from the airport to their house and the first round about off the highway there was one all disguised... more so than this one was. Was in awe.
