Portofino steering wheel adjustment | FerrariChat
Discussion in 'Technical Q&A' started by Nycdoc, Oct 17, 2020.
  1. Nycdoc
    Nycdoc Rookie
    Aug 22, 2020
    9
    Steven Karmin
    How do adjust the Portofino steering wheel?
  2. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    25,886
    DFW, Texas
    Tom C
  3. Nycdoc
    Nycdoc Rookie
    Aug 22, 2020
    9
    Steven Karmin
    I had a Cali T with the switch you refer to but I can’t find a similar switch in the Portofino. The manual says there’s a switch on the left steering column but I can’t find it. I wonder if there is a manual adjustment?
  4. Llenroc
    Llenroc F1 Rookie
    4,806
    Colorado
    Vern
    Is the power wheel adjustment optional? probably so if you do not have the switch on the steering as shown above. If so the manual adjustment is under the steering column about where your knees are when sitting in the seat. Ferrari made the power adjustment optional(from being std on ‘09-12) in 2013 on the 458 so probably did the same on other models at the same time.
    tomc likes this.
  5. Nycdoc
    Nycdoc Rookie
    Aug 22, 2020
    9
    Steven Karmin
    Yep! It has the manual adjustment. Found it. Thank you!
    tomc likes this.
