Position of door lock striker | FerrariChat
Discussion in '348/355' started by lotusk, Jan 10, 2015.
  1. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    My 355's door lock striker is a short cylinder with a series of grooves on one side of it to which the teeth on the door lock I presume catch.
    What is the correct position for these grooves to face?
    Away from the door or facing the door or some other position.
    I find that to get my doors to close flush with the rear fender you need quite some pressure on the door handle to open the door.
    If i move the striker so that the door handle needs just a gentle squeeze to open the door then the door will stand proud maybe 1mm from the rear fender which doesn't look right.
    Any comments?
  2. ncjetskier
    ncjetskier Formula 3
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    Since nobody has replied, I would have the grooves face towards the outside of the car. It sounds like you may need a new one - as when it fails - it is not good. The hitch will get stuck in the grooves and the door will not open. Happened to me, and no matter how hard I pushed on the door, it remained stuck closed. Racambi has the replacement part and failure of the striker is common.
    If I remember correctly, the striker is not supposed to rotate unless it is getting ready to fail.
  3. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Interesting
  4. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
  5. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Thanku
    I think i'll buy two new strikers
  6. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    That should have read "extend the LIFE of the striker".
    Auto spell check sucks sometimes.
