Possibe to degree qv cams while engine still in ??? | FerrariChat
Discussion in 'Technical Q&A' started by todd6363, Feb 23, 2007.
  1. todd6363
    todd6363 Formula Junior
    Jan 20, 2007
    270
    Ohio
    Todd
    Aside from being hard to do, can it be done ? Not planning on running air pump or cats, would you euro spec the cam timing ? Car is an 83 QV. I read somewhere on here that I could'nt ask a stupid question so I'm testing the waters ! Thanks
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    You decide what spec you want it set to. It can be done in the car, just a little frustrating. Get a good mirror.
  3. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Yes, it can be done. Just find a small enough wheel to clear the waterpump, etc., etc.. I have a large one and I cant use it. So I made one by copying one off the ineternet and gluing it to cardboard. Later I scribed one out of aluminum sheet. And yes, you can alter the valve timing around.
    You are a very lucky man. So how many miles are on this "Queen"?
  4. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    www.summitracing.com sells several sizes of timing wheels. Some of them are small enough so they can be mounted to the front of the damper using a triangular hole pattern for 3 screws w/washers that pick up the edge of the pulley.
  5. todd6363
    Jan 20, 2007
    270
    Ohio
    Todd
    24,000 miles - got the radiator and all the coolant out today, tommorrow draining the gas and replacing all the fuel lines.
  6. Owens84QV
    Owens84QV F1 Rookie
    Oct 2, 2001
    4,486
    Somewhere in NC
    Greg
    ...For the rear-bank cam timing marks...
