355 - Possible electronic module rear right seat? | FerrariChat
355 Possible electronic module rear right seat?
Discussion in '348/355' started by jvillarreal, Mar 16, 2024.
  1. jvillarreal
    jvillarreal Rookie
    Jan 27, 2024
    31
    juan villarreal lois
  2. Qavion
    Qavion F1 World Champ
    14,259
    Ian Riddell
    Maybe your camera needs restoring, first? ;)
    I can’t see any of the wire colours in your photos, so that’s no help to us. I can’t even see how many pins there are on the plugs.
    2.7 owners... What's that black plastic mount for? Is it just to keep the carpet in shape?
  3. jvillarreal
    jvillarreal Rookie
    Jan 27, 2024
    31
    black connector female faston:
    wire blue/yellow
    wire black
    white connector little female faston:
    wire yellow/red
    wire yellow/red
    wire brown/black
    wire brown/green
    wire green/white
    wire black
    sorry for the bad pictures...
  4. jvillarreal
    jvillarreal Rookie
    Jan 27, 2024
    31
    Ian you´re always helping a lot width electrical problems, thanks.
    Qavion likes this.
  5. Qavion
    14,259
    Ian Riddell
    Blue/yellow (or yellow/blue) might be the seat belt.
    Still looking for the other plug...
  6. Qavion
    14,259
    Ian Riddell
    I don't think this plug is used. It looks like provisional wiring for the tyre pressure monitoring system (which no F355 has... unless it was fitted to the Challenge cars?)
    https://www.dropbox.com/t/buetF0gZIFuRJTya
    See component 10013 at the bottom of the diagram.
    It's the first photograph of this plug I've seen.
  7. jvillarreal
    jvillarreal Rookie
    Jan 27, 2024
    31
    i see, i see, but i try to google that ecu and can´t find any picture, maybe it´s a future connector?
  8. Qavion
    14,259
    Ian Riddell
    Yes, that's what I mean by provisional. The 2.7 has provisional wiring for an immobiliser system, but it was never fitted to the 2.7 cars. The provisional (17 pin) plug for the immobiliser does have some jumper wires on it, however, for fuel pump control.
    Full diagram here:
    https://www.dropbox.com/t/Hsq8UAG2rnoApelv
  9. Qavion
    14,259
    Ian Riddell
    Since the plug has power on it, it may be best to wrap it with Scotch 70 or similar electrical tape to protect it from shorting.
  10. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,215
    CT
    John Kreskovsky
    Don't know if this is any help but the WSM shows this for 96 on cars. The box #7 is an interface unit to the Motronic and #8 is the alarm ECU. The wire, #9, is a diagnostic connection. So, yes, maybe future use on a 2.7 car.
  11. jvillarreal
    jvillarreal Rookie
    Jan 27, 2024
    31
  12. jvillarreal
    jvillarreal Rookie
    Jan 27, 2024
    31
    exist any reference for that ecu?
    i need to check too if exist any sensor or similar on the car then.
  13. Qavion
    14,259
    Ian Riddell
    My 5.2. car also has that light. It's a provisional light. Looking at the Challenge parts manual, the TPMU was not fitted to the Challenge, therefore no F355s have it.
    For reference, provisional immobiliser connector 59302 is located behind the relay panel. No provisional wiring goes further aft.
  14. jvillarreal
    jvillarreal Rookie
    Jan 27, 2024
    31
    ok, thanks for the info
