Possible F1 problem on F430 | FerrariChat
Discussion in '360/430' started by ucorders, Jun 15, 2008.
  1. ucorders
    ucorders Formula Junior
    Dec 27, 2005
    398
    Portland Oregon
    Coming up to a stop sign on a uphill I down shifted at the last moment since the hill gets very steep quickly. I seemed to confuse the F1 system. It started beeping like it does when you turn of the key and did not seem to want to go into gear. I shifted into second and it seemed OK but did it again at the next stop sign. I restarted the car and it seems to be fine now. Is this just a situation of the computer being confused until it is reset by starting? Has anybody else had this happen to them?
  2. The Ape
    The Ape Formula 3
    Feb 28, 2007
    1,793
    Los Angeles
    Ape
    Take it to the dealer for a check up. Yes, this is common when there is an issue with the F1 System. It's generally an easy fix, but DONT wait, get it looked at right away. I don't know how many miles are on your car or how long you've owned it, but do not worry.
  3. ucorders
    Dec 27, 2005
    398
    Portland Oregon
    Cool, I figured I would bring it in this week. It has 24k miles but it is still under warranty so it should not be a problem.
  4. The Ape
    The Ape Formula 3
    Feb 28, 2007
    1,793
    Los Angeles
    Ape
    Also, make sure they check the percentage of clutch life you have left. At 25K miles it my be time for a new clutch depending on many factors.
  5. MordaloMVD
    MordaloMVD F1 Rookie
    Sep 7, 2005
    4,222
    WA
    Michael von Ditter
    Great to hear you are driving the car. I can't tell you how tiered I get of people thinking that an F car with more than 5K miles on it is worthless.
  6. ucorders
    Dec 27, 2005
    398
    Portland Oregon
    Thanks, I bought it as a high mile car with 22k on it a few months ago with the intention of using it as a daily driver for the two years I could by the extended warranty. I bought the PowerCube warranty so I would not have to worry about anything. So far it has been great. With what I expect to lose on the car when I sell it in two years, it works out to about 20k per year for the privilege of having a F430 as a daily driver. 2005 coupes are really a pretty awesome deal right now in terms the amount of car you get for the money. Not much different than buying a BMW 7 series.
  7. racerdj
    racerdj F1 Veteran
    Jan 19, 2003
    6,952
    Indianapolis
    DJS
    Please post what the dealer says.
  8. ucorders
    Dec 27, 2005
    398
    Portland Oregon
    Talked to the dealer today. They had just seen my car recently so they knew the condition of the clutch. They felt in my circumstance it was just a case of the computer getting confused and it taking a few cycles to get it under control again. I guess the bottom line is shift when it is in gear and not when it is already shifting. I've driven it for about three hours since the incident with out a problem so it looks pretty good. Thanks for all the input.
  9. J2J
    J2J Formula Junior
    Jan 11, 2008
    271
    Interesting...mind if I ask what you paid for an '05 430 with 22k miles?
