Possible to install an exhaust vacuum valve? | FerrariChat
Discussion in 'Technical Q&A' started by Zed82, Nov 7, 2019.
  1. Zed82
    Zed82 Formula Junior
    Sep 28, 2017
    520
    Sweden
    I have a Tubi exhaust without valves. Could i buy a pair of vacuum valves and install them? Anyone done this?
  2. tazandjan
    39,334
    Should work fine. Right now nearly all the exhaust gas is exiting through the inner pipes with little flow through the outer ones. On the valved versions, the flow is through the higher back pressure and more silenced outer pipes. Adding the valves should give you just what the factory valved version does. You need a pretty good welder to pull this off, plus the factory system to open and shut the valves or one of Steve Bissel's aftermarket systems.
    Zed82 likes this.
