Possible to pass smog in Cali without thermo reactor? | FerrariChat
Discussion in '308/328' started by JMNGTB, Feb 20, 2014.
  1. JMNGTB
    JMNGTB Rookie
    Dec 25, 2008
    48
    Have 1977 308 GTB with carbs, but now with new stainless Novi muffler just installed. Has anyone else been able to pass smog test with a aftermarket muffler in place of the factory thermo reactor? Cheers, John.
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,572
    San Carlos, CA
    Mitchell Le
    No, you will fail the visual inspection.
  3. JMNGTB
    JMNGTB Rookie
    Dec 25, 2008
    48
    I got the visual aspect covered. More interested if someone has passed on tailpipe readings. Thanks, John
  4. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,030
    I want to say "Yes!" ----But CA is tricky on what they require. The fact that you are cool on visual is great. That part always is a headache to me, especially when they gripe about no EGR, and the carb cars never had these!
    Anyway, do you know what they are demanding for tailpipe requirements? I can give you a better answer knowing those. ie is CO requirement down approaching 1%, and HC about 175? Or is it more generous? Also - What is the tune condition of your car? Dizzies spot on and in synch (assuming you have the twin dizzy setup). Do you have the AIS hooked up, and is your airpump good? Carb's are reasonably synched? If you have every bit of equipment, you can cry to the referee. If not, make it pass by making it clean.
    Thermal reactors are good at helping burn the exhaust pollutants, but a good AIS pumping into an exhaust system can do pretty well. Again, it depends what you gotta meet. Best of luck!
  5. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,811
    Cerritos, CA.
    Before, I was able to pass smog with my shiny stainless steel muffler with no problem as long as you have good cat pass all the emissions. They did however ask to see my charcoal canister but when the found out it's hidden as you have to take the wheel and the wheel well liner, they said it's ok, they don't need to see it.
  6. GT4 Joe
    GT4 Joe Formula Junior
    Oct 19, 2010
    833
    Dana Point, Ca.
    Joe Williams
    I don't really think the smog guys know what they are looking at. They couldn't tell an original TR muffler from a Tubi. So, it's all about the tailpipe readings, really. I think on a '77, the standards are relaxed enough that it may just magically pass....
    If not, then you've got a lot of work ahead of you! Exactly why I drive an EXEMPT '75.
    My 2 cents.
  7. miketuason
    Feb 24, 2006
    15,811
    Cerritos, CA.
    #7 miketuason, Feb 21, 2014
    Yes, that is true, and that's why and how mine pass all the time before with this SS Larini exhaust even without the diaper.
  8. JMNGTB
    JMNGTB Rookie
    Dec 25, 2008
    48
    The GTB have been in the loving hands of Tom at Marelli Service in Los Osos last couple months. Carbs done alongside with the Dists and everything else. Tom did a major tune and she has not run this well in some 20 years. Canister in in place, need to install air pumps. Next week I will get a test only to establish a baseline to see how close we are. Might need to use some fuel additive and back down the advance, we will know more next week. Stay tuned, no pun intended!Cheers, John.
  9. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,786
    Marin
    Geno
    +1
  10. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,030
    That sounds great! An intelligent mechanic who's on your side is a huge plus. You should be most the way there. Now keep in mind that with a good AIS in place, you want it to be a little fat so the air will have a little fuel to continue burning. This is also benefited by a little ignition retarding (R-2 set of points). If you're near lean drop-off, the AIS will help, but follow the TR recipe on the emission label for tuning. Ferrari spent gobs of time developing this. Also, your jetting should be close to the original recipe too. IIRC you have 55 idle jets + or -. If you're off a size, it's a little tolerant. Unless you are on the fence. I chased down 20-40 ppm HC for a long time, and was helped out by throwing out to the F-chat world, and one of them got it! :) Again - do yourself a favor and figure out what specs you need to pass. Is yours a static test, or dyno 15 & 25MPH? A 1977 might be not-too-terrible, or - - - - - - - Keep your fingers crossed!
  11. JMNGTB
    JMNGTB Rookie
    Dec 25, 2008
    48
    And the answer is right on top. Cheers John.
