Possibly unheard of electrical issue on 355? | FerrariChat
Discussion in '348/355' started by TheFNG, Oct 1, 2024.
  1. TheFNG
    TheFNG Rookie
    Mar 23, 2023
    18
    Fort Walton Beach, FL
    Justin Adams
    Lots of threads out there about electrical issues on these cars, but I haven't seen this one yet. Trying to dia a 355 and was initially thinking it was an immobilizer issue. Have now discovered that there is 1v flowing through the body with nothing on. Has anyone seen this before. Car was running previously. Sat for a couple weeks, battery drained and when charged, it hasn't started since. Any input is appreciated.
  2. m.stojanovic
    m.stojanovic F1 Rookie
    3,316
    Serbia - Niš
    Miroljub Stojanovic
    Interesting. How exactly did you establish that there is 1v flowing through the body with nothing on?
    WATSON, Qavion and Rifledriver like this.
  3. Rifledriver
    37,348
    With a charged battery disconnect the battery negative cable and jump it with an amp meter. See how many miliamps with nothing on and the car closed up.
  4. TheFNG
    TheFNG Rookie
    Mar 23, 2023
    18
    Justin Adams
    I apologize, I have new information that it is as the car is cranking. No voltage when the ignition is in the on position, but only when the starter is cranking. Strangest thing
  5. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,294
    CT
    John Kreskovsky
    There are some weird things about the 355. For example, when I was changing the headers on my car, with the battery switch turned off, if the cage around the bulb of my drop light touched the frame the doors would lock. Remove the drop light and they would unlock. I thought maybe the cage was grounded but when I checked it was completely electrically isolated from all 3 wires in the cord. Go figure. o_O
  6. fatbillybob
    Aug 10, 2002
    29,426
    socal
    You can predictably use an ammeter at the battery to estimate a battery drain in milliamps". Then you pull Fuses to find the offending circuit and narrow down the culprit from there.
    WATSON likes this.
  7. Qavion
    Qavion F1 World Champ
    14,641
    Ian Riddell
    #7 Qavion, Oct 1, 2024
    As previously asked, where/how are you measuring this voltage?
    Batteries don't like being flattened. I wouldn't have any confidence in a modern battery being flattened completely. I would suggest replacing it.
    If you do have an ammeter hooked up in line with battery, I don't think I would turn on the ignition or attempt to start the car. The current draw may exceed the limit of the ammeter. Common multimeters usually only go to 10amps. A clamp type ammeter may be better for doing these tests.
  8. Qavion
    14,641
    Ian Riddell
    Since it is so hard to access the battery on the 355, perhaps you could provide us with more details, and we can come up with some solutions which won't involve pulling the wheel and wheel well liner off the car.
    308 GTB likes this.
