Post-grounding 787 Dreamliner problems | Page 2 | FerrariChat
Discussion in 'Aviation Chat' started by targanero, Jun 25, 2013.
  1. beast
    beast F1 World Champ
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    Depends on why they replaced it. If they sucked something thru the engine that damaged the blades is not that uncommon of a cause for a replacement.
    Thomson had to replace one of the engines on a new 787 when it sucked a bird through the engine and found damage to the blades post flight.
    Incident: Thomson B788 at Cardiff on Jun 25th 2013, bird strike
  2. targanero
    targanero Formula 3
    May 31, 2005
    1,661
    New York
    Simon
    Definitely unfortunate. The question is how coincidental it is. 6k of these ELTs have been installed on passenger jets without a fire. The first blaze was on one of the relatively few 787s in service.
  3. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    I was wondering that too...it seems like almost every one of the big problems faced by the 787 have been electrical - often resulting in a fire. Could it be surging the main bus up and down over the limits of the batteries and the components?
  4. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,018
    Shoreline,Washington
    Robert Parks
    Most of the problems with the 787 are vendor problems that have surfaced because of insufficient quality control procedures at the vendor level and incoming quality control. Not what it was in the past.
  5. MarkPDX
    MarkPDX F1 World Champ
    Apr 21, 2003
    15,111
    Gulf Coast
    Well if nothing else this stuff doesn't seem quite as scary as the engine trouble and wing crack issues in the A380.
  6. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    I should have been more concise in my statement. The 787 program architecture and concept is totally different than all others. The 777 program is solid and productive, as is the 767,737, and 747. The 787 will be good too but it will have to go through some aggressive corrections in the supplier side. The airplane is well engineered and a good concept. Execution needs and is getting some effective adjustments in the afore mentioned areas. This airplane is a winner.
  7. beast
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    Now my question is in the past would Boeing go and open up avionics and other equipment from outside vendors to make sure that it was assembled correctly?? I would think not as it might cause the potential of damaging the equipment or a vendor getting upset that there intellectual property being reversed engineered.
  8. CornersWell
    CornersWell F1 Rookie
    Nov 24, 2004
    4,899
  9. jcurry
    24,153
    In the past
    Jim
    In addition to expense it will add wt and will likely be visible to the discerning eye. It will also not be as strong, although it will meet all regulatory requirements. Included with the repair will be additional periodic inspection requirements, re more maintenance costs.
    Given that the event was a 'from the factory' issue the airline has a lot of room to pressure Boeing. Doubt if they can get a whole new airplane but they could require a factory rebuild of the aft fuselage.
    But not to worry, Boeing already has a spare airplane ready to go. There is at least one brand new Ethiopian Airlines 787 sitting on the ramp at Boeing. Looks like it just came out of the paint hangar a few days ago.
  10. targanero
    targanero Formula 3
    May 31, 2005
    1,661
    New York
    Simon
    In a statement on Wednesday, Qatar Airways said a delay in shipping a replacement part from Boeing "caused an extended grounding" of the Dreamliner, one of six in its fleet.
    The airline did not say what part was needed or what problem occurred, but stressed it was committed to safe operations.
    "Qatar Airways takes all matters affecting the safety of its passengers seriously," it said.
    Qatar Airways said several replacement parts were required for the repair. After the delayed part arrived, the 787 needed three days of "post-assembly and testing" before resuming service, the airline added.
    Qatar Dreamliner returns to service after 10-day hiatus | Fox Business
  11. targanero
    targanero Formula 3
    May 31, 2005
    1,661
    New York
    Simon
    ANA discovers electrical wiring faults with engine fire extinguishers in three 787s.
    As a result, rival airline, JAL, recalls a flight en route to Helsinki so all ten of their 787s can be inspected.
  12. targanero
    targanero Formula 3
    May 31, 2005
    1,661
    New York
    Simon
    It looks like boeing still hasn't addressed QC on the 787 line. This is one of the latest delivered.
    According to Reuters:
    Budget airline Norwegian Air Shuttle is returning one of its brand new Dreamliners to Boeing, demanding repairs after the jet has suffered repeated breakdowns, it said on Saturday.
    Norwegian Air Shuttle will instead lease an Airbus A340 from HiFly to keep its long-haul business going and will not take back the Boeing 787 Dreamliner until it is more reliable, a spokesman said.
    "The aircraft's reliability is simply not acceptable, our passengers cannot live with this kind of performance," spokesman Lasse Sandaker-Nielsen told Reuters.
    "We are returning the aircraft to Boeing to improve its reliability."
  13. Peloton25
    Peloton25 F1 Veteran
    Jan 24, 2004
    7,646
    California, USA
    Erik
    Still not looking good here. I know the complexity of a plane like this is beyond compare almost, but I certainly don't recall such a bad start for any others.
    >8^)
    ER
  14. Jet-X
    Jet-X F1 Veteran
    Nov 2, 2003
    5,694
    Washington State
    Brian
    Boeing's spokesperson said that the 787 is only achieving a 95% dispatch. In other interviews they say this is on par with the 777 when it was introduced. However, that's not accurate. The 777 was treading at 96.5% and not long after 98%.
    The 787 which has been flying since late 2011 is still trailing the 777 with no end in sight regarding reliability across the board.
    Dreadful. Norwegian is *****ing. JAL is *****ing. Qatar is *****ing. It won't end...
  15. Jet-X
    Jet-X F1 Veteran
    Nov 2, 2003
    5,694
    Washington State
    Brian
  16. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    That panel is not retained by rivets. You can see the flange in the foreground with what appears to cam lock fastener openings. Inside the exposed area it looks like AC packs and this would have nothing to do with the batteries. One must examine how the maintenance was done on the aircraft since it is now in the hands of an operator. Just my guarded impression from can be seen in the picture.
  17. Jet-X
    Jet-X F1 Veteran
    Nov 2, 2003
    5,694
    Washington State
    Brian
    You're right Bob - I only post this because you know the media will have a field day with it, especially in light of all (and the continued) problems with the 787.
    Two years into service at this point, and the problems don't seem to be subsiding.
  18. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    I have just verified that it was the access panel to the AC bay. For this panel to depart the airplane without damaging anything indicates that it was improperly installed or maybe not at all. To be able to take a panel off a parked 787 and install it on another 787 aircraft indicates a maintenance failure, NOT THE AIRPLANE .
  19. Tcar
    Tcar F1 Rookie
    I'm guessing that the author of the article has no idea what the difference is between a rivet and a cam-lock fastener.
  20. Jet-X
    Jet-X F1 Veteran
    Nov 2, 2003
    5,694
    Washington State
    Brian
    The public reading this doesn't understand the difference between a rivet and a cam-lock fastener. Even if the author did, and explained it, public sees "panel falls off of 787 in flight"
  21. Peloton25
    Jan 24, 2004
    7,646
    California, USA
    Erik
    And isn't in the airlines best interest to suggest that's what happened, rather than allude to the fact it could have been a maintenance issue? ;)
    The second side of this story is Boeing's and it would be "interesting" to hear them weigh in.
    >8^)
    ER
  22. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    I think that you are absolutely correct and no amount of correction will change it.
  23. Jet-X
    Jet-X F1 Veteran
    Nov 2, 2003
    5,694
    Washington State
    Brian
    Bob, here's hoping the 777-8/9X has a smoother launch and EIS.
  24. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    I am no longer a part of the current 777 program so I can't speak with much knowledge about it. It is a different animal from the 787 and it has the lineage of a program that was the benchmark of how to design and build an airplane. Good people are working on the derivatives and I feel that they are an extension of what started well and so far is producing a winner.
  25. Tcar
    Tcar F1 Rookie
    #50 Tcar, Oct 16, 2013
