power antenna Stuck | FerrariChat
power antenna Stuck
Discussion in '308/328' started by SBrooks, Jul 20, 2010.
  1. SBrooks
    SBrooks Formula Junior
    Jan 27, 2009
    778
    Bend Oregon
    Sam Brooks
    it went up about half way and stopped will not go up or down dont but the motor does try to move it
  2. BigTex
    BigTex Seven Time F1 World Champ Owner Rossa Subscribed
    Dec 6, 2002
    79,368
    Houston, Texas
    Bubba
    It sounds like your nylon driver spool went ka put.....there's repair kits available, or I do have one working unit that someone stole all the top fittings from it....
    It's just lying around.....
    Take it apart and see if that's the case......
  3. sdfovc2003
    sdfovc2003 Karting
    Aug 17, 2009
    54
    I had the same problem and all it took was a lube of the antenna and it worked perfectly.
  4. SBrooks
    Jan 27, 2009
    778
    Bend Oregon
    Sam Brooks
    hmmm I will it a try that did you use WD40 or something else?
  5. sdfovc2003
    sdfovc2003 Karting
    Aug 17, 2009
    54
    I don't think they used anything special. WD-40 should work. There was also a small bend in the antenna which was hampering its performance. I lost points at my last concours because the antenna would only go partly up.
  6. carb308gtb
    carb308gtb Karting
    Oct 20, 2006
    188
    Svezia
    Patrik
    You can use WD40 to make it work again, but WD40 also removes lubrication so you have to put in new lubricating, I use Teflon/Silicone lubricants and it works fine. Just wipe it off with a rag.
  7. BigTex
    Dec 6, 2002
    79,368
    Houston, Texas
    Bubba
    I go with Royal Purple 20-50W.....LOL!
    Definately get the kink out....
  8. SBrooks
    Jan 27, 2009
    778
    Bend Oregon
    Sam Brooks
    yea i have 10w40 lying around when im not busy i might put some on a rag and wipe it on the antenna
  9. FLVICE
    FLVICE Formula Junior Silver Subscribed
    Jun 28, 2006
    922
    Ft. Lauderdale
    Edward
    mn
  10. sammyb
    sammyb Formula 3
    Jun 23, 2006
    1,857
    Where wife tells me
    Sam
    There is a nylon line inside that acts like a fishing rod -- it turns one way and pushes the line out to extend, then turns the other way and retracts the line and antenna. If it breaks, there's nothing connecting the motor to the actualy antenna mast, so the motor just turns and nothing moves externally.
    If the motor sounds normal, but nothing moves, this is your problem.
    If the motor sounds like it is binding, then it actually is jammed.
