Power boost for a 308gtsi | FerrariChat
Discussion in '308/328' started by Morrie, Jan 28, 2009.
  1. Morrie
    Morrie Karting
    Nov 4, 2003
    207
    Sarasota/Asheville
    Are there any practical and not super expensive options? I don't want to put a blower on it. FWIW, We have no state emissions tests in Florida. At least not now.
    Morrie
  2. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,126
    E ' ' '/ F
    Snike Fingersmith
    #2 GrigioGuy, Jan 28, 2009
    Hemi powered flatbed :D
    You have a QV, so there's not a lot of options. Turbocharger, supercharger, or maybe carb conversion for a few horses. The money is better spent "upgrading" to a later model.
  3. OCFerrari
    OCFerrari Karting
    Jan 20, 2009
    124
    #3 OCFerrari, Jan 28, 2009
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,741
    The twilight zone
    no :(
  5. Morrie
    Morrie Karting
    Nov 4, 2003
    207
    Sarasota/Asheville
    It's a 1980 2-valve car. I have never driven one, but will do so this weekend. I don't know how it compares to my previous 308 QV and 328.
  6. GrigioGuy
    Nov 26, 2001
    33,126
    E ' ' '/ F
    Snike Fingersmith
    Ah, sorry, your profile threw me off. Best answer, early cams and a carb conversion. Ask Russ (snj5) about that. Probably still not cost effective
  7. OCFerrari
    OCFerrari Karting
    Jan 20, 2009
    124
    In that case, throw a couple extra hampsters in the engine compartment.
  8. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    A fellow who used to frequent the forum did a bit of work on the 2V injecteds. He claimed they would run okay with early carb cams, and IIRC, he ran intakes only and left the original exhausts. There were some other discussions about recalibrating the WUR or otherwise altering fuel pressures at idle to keep the fluttering sensor plate from altering fuel mixture at idle and low speed.
    The CIS does not like reversion waves (backflowing air pulses) hitting the sensor plate, it causes the fuel mixture to go over rich. And the early cams being longer duration do produce reversion. But its been discussed that its not as bad as claimed and can be tuned down to make the car quite driveable.
    One other person claimed that with ported heads and early carb cams on a CIS motor, to have pulled nearly 270HP RWHP on a dyno, but this was never confirmed.
    If I had one of these cars I would try the early carb cams and see how it runs. You can always go back if it doesnt work out well, or keep going forward with carbs, etc., if it does. Another option is a larger throttle body and larger smooth bore intake snorkle (between the CIS unit and throttle), which should work in theory to add "some" power. But as no one ever opened up the plenum behind it to the same bore diameter, no change in HP was ever noted (nor is this surprising). Unfortunately, Kermit left the scene and disappeared a couple years ago, and no one has done any further work on these cars since.
  9. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    +1 to everything Paul said.
    The basics:
    Exhaust: replace old heavy muffler/thermal reactor with lightweight true dual flow ehuast. See current cheap 308 exhaust thread to get started, but many more.
    Make sure everything there is in the best condition and works well.
    Your current K-jetronic will fed up to 270 hp, if you can get your engine to flow that much air (cams, heads). It is also a terrible flow restriction in itself, and you will pick-up 20 hp just retro-fitting to Webers.
    If you want to keep the original injection, the order is: K&N air filter (debatable), metal flow tube replacing rubber accordian tube to throttle, cams with more lift, cams with more lift and a little more duration, port the heads, port the heads with larger valves. We've never talked about extrude honing the manifold and plenum, but a some Porsche guys do that.
    Good luck!
