Power brake failure in 355 Challenge... | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by rob lay, Feb 13, 2005.
  1. Cavallino Motors
    Cavallino Motors F1 World Champ
    May 31, 2001
    14,143
    Florida or Argentina
    Martin W.
    CAREFUL!!!!
    I read in the 360Challenge manual not to charge the battery or jump it with the main power switch (red cut off) in the OFF position!!! it can damage the entire electric system! Find out if that is true for the 355CH as well! I am almost sure!
    As for the batterie:
    I had my 355CH batterie replaced a month ago when it did the same thing. It was probably the battery itself. Not a gel but a Interstate. The problem I had was that the vibration of the car rattled the batterie so hard that the various metal plates in the batterie came lose and shortened it out!
    Yep, Challenge cars are a lot of fun :)
  2. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    64,559
    Southlake, TX
    Rob Lay
    Will this still work OK in the garage? Just a few windows?
  3. rivee
    rivee F1 Rookie
    Jan 20, 2002
    3,731
    Nowhere important, USA
    Yes. Although mine at my trailer is on the roof, it's also under a huge Oak tree, so it never really sees the sun directly. All you need is an occasional light source, weather natural or artificial. Obviously the brighter the better, but not crucial.
    Put it close to a window and you'll be fine.
