Power loss | FerrariChat
Power loss
Discussion in '456/550/575' started by Bader87, Nov 12, 2023.
  1. Bader87
    Bader87 Rookie
    Sep 13, 2023
    21
    Bader
    Hello All
    my 99 550 maranello losses power on semi sharp turns for a few seconds then the power all comes back at once if you still have your foot on the pedal. Happens when my gas tank has less than half or is close to quarter.
    any help would be greatly appreciated.
  2. tazandjan
    tazandjan Three Time F1 World Champ Lifetime Rossa Owner
    39,163
    Have you changed the fuel filters recently? May be full of disintegrated rubber from the pump mounts.
    fatbillybob likes this.
  3. Aerosurfer
    Aerosurfer Formula 3 Silver Subscribed
    Nov 21, 2020
    1,879
    Indianapolis
    Nick
    Qavion likes this.
  4. Mirek
    Mirek Formula 3 Silver Subscribed
    Oct 20, 2019
    1,492
    Los Angeles, CA
    Mirek
    Mine (2003 456M GTA) used to do this as well. Quite annoying. Since that time I have had my fuel filters replaced (had some sand) as well as the fuel pump rubber cleaned out, injectors cleaned and new gaskets, plugs, wires, major service, new fluids/filters including for that killer GTA 3 speed w/OD absolute banger of a transmission, new throttle cables, idle adjusted, cooling upgrades, BCM filters, new suspension & bombs, MSW ECU, etc, etc….
    Between now and then, I have had done so much to bring the car up to “perfect” mechanically, that if I even attempt to touch the throttle in the same turns (that bothered me) the traction control trips.
    The damn thing is so much quicker/ torquier now that it would likely go sideways if I did not have the traction control turned on (attempting the same turn with the same amount of throttle). Very happy with this. As a result, I do not know if it still exhibits the problem but I will check and report back when my car gets back….from more repairs :(
    Qavion likes this.
  5. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,269
    Ian Riddell
    You said you had no lights. Did you get any codes?
    What caused you to start looking for a Motronic ECU. Did you find one?
  6. fatbillybob
    fatbillybob Two Time F1 World Champ Consultant Owner
    Aug 10, 2002
    28,981
    socal
    Just to make sure it is the fueling issue vs. traction control, try the turn with traction control off but make sure you are not exceeding your talent or safety on the streets.
  7. Bader87
    Bader87 Rookie
    Sep 13, 2023
    21
    Bader
    i will have to check them..but i got them replaced last year.
  8. Bader87
    Bader87 Rookie
    Sep 13, 2023
    21
    Bader
    Bought alot of breather and ventilation valves, i will install them this week and update the forum.
    Qavion likes this.
  9. Bader87
    Bader87 Rookie
    Sep 13, 2023
    21
    Bader
    I have a few parts to install, i hope the problem will go away. Happy you got your problems solved
  10. Bader87
    Bader87 Rookie
    Sep 13, 2023
    21
    Bader
    No i have no lights in, i did not look into my ecu’s.
  11. Bader87
    Bader87 Rookie
    Sep 13, 2023
    21
    Bader
    I know its not the traction, what i think the problem is that when my gas tank is below 1/4 on turn of of my fuel pumps and or fuel line goes dry for a few seconds.
  12. Qavion
    Feb 20, 2015
    14,269
    Ian Riddell
    Maybe the little filters on the base of the pumps are not fitted properly (as shown in the YouTube video in the other thread).
  13. Bader87
    Bader87 Rookie
    Sep 13, 2023
    21
    Bader
    That could be it i will have to check it out, one thing i’m sure of is that my problem is from the fuel pick up system because when the car has a full tank of gas this problem never happens. I just tried the same turns and roundabouts with a full tank and higher speeds, the loss of power never happened.
  14. fatbillybob
    Aug 10, 2002
    28,981
    socal
    Not likely. Pump gets fouled by debris mixed in tank from failing rubber bits. Tank likely needs service per TAZ post above. This is a known issue these cars do this. Almost every 550 tank in the fleet has been serviced or will need servicing.
    Bader87 likes this.
  15. Mirek
    Oct 20, 2019
    1,492
    Los Angeles, CA
    Mirek
    I read that the 456M fuel pumps ran at full bore the whole time regardless of throttle or speed so injectors generally would not “get clogged” at a random speed or RPM (maybe) assuming everything in the tank was not already turned to a sludge running throughout the system-which would be most unfortunate. Maybe fuel starvation (?) but I have to believe the gas tank is baffled (or something) to prevent that, it is a Ferrari after all. Anyway the 456M itself went around the Fiorino test track faster then the 512TR if I am not mistaken so it must be something wrong and look forward to what you find.
    Bader87 likes this.
