Power shifting 458? | FerrariChat
Power shifting 458?
Discussion in '458 Italia/488/F8' started by AWSOM50, Mar 29, 2015.
  1. AWSOM50
    AWSOM50 Rookie
    Mar 29, 2015
    18
    United Kingdom
    New here. I've picked up a lot of info from googling / searching this forum. I picked up my 458 Spider last week. Wow, I it's better than I ever thought - I'm addicted. No buyers remorse here. Can't wait for the UK weather to clear up.
    Anyway, question: when in race mode, should I lift/feather the throttle a little when shifting up? If I keep the pedal floored it bounces up a few hundred RPM - sounds great and shifts quick, but is it safe for the car to do so?
  2. BlueIn2Red
    BlueIn2Red Karting
    Sep 29, 2006
    234
    Tring, UK
    You shouldn't lift. RPMs shouldn't "bounce" on up shifts though, it should be a basically seemless rev drop to the next gear.
  3. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    In any mode. Will lead to very jerky shifts. Not good for the dct.
    Enjoy.
  4. Rcktrod
    Rcktrod F1 Rookie
    Dec 21, 2010
    3,946
    Plaster the pedal to the floor and smile away!
  5. DK308
    DK308 F1 Rookie
    Aug 13, 2013
    2,738
    Europe, way north.
    AB
    When in doubt... NAIL IT!!!:D
    Anyway, I've never seen a bounce and even in race mode @ WFO, I feel the shifts are quite smooth. If you're having RPM "fluctuations" in the range of a few hundred RPM, keep an eye out and perhaps take it to the dealer. Never seen that in any 458 on up-shifts.
  6. AWSOM50
    AWSOM50 Rookie
    Mar 29, 2015
    18
    United Kingdom
    Thanks guys, so it looks like 3 for flooring it, and 1 against?
    I'll look at the tach when I drive it next, perhaps it is only 50 - 100 rpm, but it is a very small audible rev blip while the shift occurs - sounds as I would expect.
  7. DK308
    DK308 F1 Rookie
    Aug 13, 2013
    2,738
    Europe, way north.
    AB
    No. There are 4 for flooring it and 0 against.
    Forget everything you know about manual transmissions, it's apples and oranges, with no such thing as "powershifting". The system will blip the throttle, rev match and what not. it is all taken care of, and designed to be run that way. By feathering, you only get jerky shifts and upset handling. When you drive at an easy pace it's the same. Treat your right foot as you would in a car with an automatic i.e, keep a constant throttle position when it shifts.
  8. Surfah
    Surfah F1 Rookie
    Dec 20, 2011
    3,144
    +458
  9. AWSOM50
    AWSOM50 Rookie
    Mar 29, 2015
    18
    United Kingdom
    Understood, thanks!
