Power Steering 355 | FerrariChat
Power Steering 355
Discussion in '348/355' started by GWood355, Nov 11, 2007.
  1. GWood355
    GWood355 Karting
    May 24, 2006
    108
    Little Rock, AR
    Gregory D Wood
    I have a 97 355 GTS. I have not had any problems thus far with the car until today. I went for a drive around town and about 5 minutes into driving I noticed the power assist steering went out. No noise or rattles, just off like a switch. Any suggestions? Is there a trouble shoot table to run down to isolate the problem. Is it OK to continue to drive for now or can it cause further problems. Thanks for any help/input.
    Greg
  2. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Must have spat the p/steering belt off mate. :):)
  3. GWood355
    GWood355 Karting
    May 24, 2006
    108
    Little Rock, AR
    Gregory D Wood
    Thanks for the input. It is difficult to see in that area, can you see better from below. It must have happened in my neighborhood, but I have not seen any evidence of belt on the road. Could it have gotten tangled up in the engine somewhere? I am always listening for odd noises/sounds and I did not hear a thing when it happened. I have not been able to look and confirm if the belt is off because I can see good enough in that area. I felt around and it feels like there is a plastic cover over the belt area but I am not sure. Any suggestions?
  4. PAP 348
    Dec 10, 2005
    100,220
    Pap
    #4 PAP 348, Nov 13, 2007
    Here is a pic from the front of a 355 engine. :)
    The p/steering belt is circled in white. The belt could be caught up somewhere in front of the engine mate. You may have to place car on some chassis stands and get underneath it to have a look. :):)
  5. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Probably the ps belt like Pap says, but 355's have 2 different ps fluid reservoirs (some 355's have a metal one, others have a plastic unit). The plastic ps reservoirs are known for failing and leaking out the ps fluid.
    Checking the ps fluid is easier than checking that belt, too!
    That would be my first place to look.
    Can you drive without power steering? Yes, but you don't want pieces of a broken ps belt getting caught up in your cam belts/pulleys (low probability, but it could ruin your engine if it occurred).
    Best to check things out, first.
  6. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Good info there ND and PAP :)! The PS pump adjuster bolt could have loosened up causing the belt to lose tension.....?
  7. GWood355
    GWood355 Karting
    May 24, 2006
    108
    Little Rock, AR
    Gregory D Wood
    Thanks! I know what I am doing this weekend.
  8. 355Aussie
    355Aussie Formula Junior
    Jul 3, 2007
    688
    George
    From someone that knows don't drive it.
    You may 'cook' the pump and then we are talking big dollars.
    Need to find out if you have a hose that has busted or belt or something else but like I said do you want to 'cook' the pump by driving???
