Power steering bleeding question | FerrariChat
Discussion in 'Technical Q&A' started by Smiles, Jul 10, 2019.
  1. Smiles
    Smiles F1 World Champ Lifetime Rossa Owner
    Nov 20, 2003
    16,675
    Pittsburgh, PA
    Matt F
    What is it about raising the front end, with tires off the ground, makes bleeding a power steering rack so effective?
    I did the equivalent of 20 turns lock to lock while driving. I then put it in the air and did the same and it's well bled and smooth again.
    Flaming River in my '61 Corvette, if it matters.
    Matt
  2. thorn
    thorn F1 Rookie Silver Subscribed
    Aug 7, 2012
    3,324
    Tallahassee, FL
    The off-the-ground element is mainly to make steering easily end-to-end, and without extra tire wear. In itself, it doesn't really have that much more effect on the bleed.
  3. Smiles
    Nov 20, 2003
    16,675
    Pittsburgh, PA
    Matt F
    Thanks.
    I could swear it made a ton of difference to not have a load on the tires.
    I really wonder why.
    Matt
  4. tbakowsky
    tbakowsky Two Time F1 World Champ Consultant Professional Ferrari Technician
    Sep 18, 2002
    20,042
    The Cold North
    Tom
    No cavitation of the fluid which can introduce air into the system. Cavitation occurs while trying to bleed the system with the full weight of the car on wheels with an empty system.
    Beetle and Red 27 like this.
  5. Smiles
    Nov 20, 2003
    16,675
    Pittsburgh, PA
    Matt F
    Thank you!!!
    Matt
  6. thorn
    Aug 7, 2012
    3,324
    Tallahassee, FL
    Was wondering/hoping if someone would chime in with a bit more technical input. Thanks for adding that bit, Tom. Wasn't aware of it, happy to learn more.
