What do you call this type of fitting? I need seals for these fittings as well as others like fuel lines and such. I need 44,45,47,48 media001.jpg[img/] [ATTACH=full]122988[/ATTACH]
Those are crush washers, usually made out of annealed alluminum or copper. They could be reannealed and reused but they should be cheap enough to just replace them. To reanneal, just gently heat them with a propane torch or over a gas stove (not too much heat) and quickly cool the in cold water. If you did it right, they will be VERY easy to bend.
Banjo Fittings!!!! Wow. Well i dont have the old ones to try to repair so i am going to look for some new. Thanks for the help.
