Power Steering Fluid for 360 | FerrariChat
Discussion in '360/430' started by collegeboy, Jan 19, 2023.
  1. collegeboy
    collegeboy Formula 3
    1,317
    Texas and Kaua’i
    Mikey
    Wanting to pump out my CS power steering reservoir and refill it with new fluid. Then do this repeatedly for a while to get mostly new fluid in the system over time. I am planning on using Amsoil ATF for this. They have both Dexron III and Dexron VI available. The car is stated to use III, but I believe that IV is backwards compatible. Thoughts?
  2. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,072
    Josh @jtcarprojects
    Vl redline
  3. Mario Andretti
    Mario Andretti Formula 3
    1,748
    Boston
    Mobil 1 ATF
    Mobil 1 Synthetic ATF is a multi-vehicle formula recommended for use in modern high performance automobiles, SUV's, SUT's, vans and other light trucks
    • Recommended by ExxonMobil for use in applications requiring Dexron III , Ford Mercon and Mercon V performance levels
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,918
    Isle of man- uk
    On the 430 you can use the same fluid as the F1 system. The F1 system is a higher spec and fine to put in the steering. They list a different fluid for the steering but just not available, hence use the f1 stuff
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,678
    Central NJ
    Dominick
    For the power steering pump giving seals etc i do not recommend the same as the F1 system.
    I would use "castrol dex Merc for older cars"
    Some.of the others mentioned are not advised for PS Image Unavailable, Please Login
  6. Rifledriver
    36,770
    imahorse and AandSC like this.
  7. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    918
    TX
    +1 on what Brian said.
    I previously pumped out all my steering fluid and put in Pentosin CHF202 and it turned black very quickly and didn't provide great feel.
    Brian recently changed my fluids and used the above Red Line power steering fluid and it's much better now.
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,678
    Central NJ
    Dominick
  9. tazandjan
    39,025
    In the olden days, several manufacturers produced a specific power steering fluid, but these were discontinued. Nice to see Red Line makes one. Incidentally, some manufacturers state not to use Dexron VI in power steering, but Dexron III is OK.
  10. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,072
    Josh @jtcarprojects
    Been using Vl in my ps for 5 years. It superseads III
  11. collegeboy
    1,317
    Texas and Kaua’i
    Mikey
    Thanks for the replies. See now this was the confusing thing for me. Some people are saying any Dex IV is good. Others are saying Dex IV is bad for PS systems.
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,678
    Central NJ
    Dominick
    At the end of the day
    ..either go with was.in there originally.. a older spec IIIh Dex or a.dedicated PS like rifle driver mentioned
  13. Rifledriver
    36,770
    Every OEM had their own. There were always accusations it was just ATF at a higher price? Who knows.
    Been using Redline for a long time. Many Ferraris get the fluid very hot and destroys the oil. In some cases it expands so much it will overflow the reservior. Redline seems to be better on both counts.
  14. collegeboy
    1,317
    Texas and Kaua’i
    Mikey
    Wait, so don't use ATF? Amsoil makes a Powersteering fluid as well. That's what I should actually use?
  15. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,918
    Isle of man- uk
    That recommendation came from my ferrari service manager
  16. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,678
    Central NJ
    Dominick
    #16 flash32, Jan 20, 2023
    What i saying is use the older ATF that i provided a link to which is pretty much what was in there from factory or use the PS fluid rifledriver mentioned....i would stay away from more modern ATF due to possible seal issues
    Actually ...i also recommend this fluid (link and picture above) for early 360 F1 systems as well due to some concern of seals .. f430 F1 system i recommend the ATF sync from Mobil 1 (non lv version)
  17. collegeboy
    1,317
    Texas and Kaua’i
    Mikey
    That’s great. I will go buy some “Castro Dec Merc for older cars” tomorrow for my PS and F1 systems in my Stradale. Thank you!
  18. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,678
    Central NJ
    Dominick
    By the time the stradale was made iirc the seals were updated in the F1 system so you should also be ok with Mobil 1 syn Dex/Merc version..
