Power steering hoses | FerrariChat
Discussion in 'Mondial' started by UsernameBob, Oct 9, 2025 at 3:35 PM.
  1. UsernameBob
    UsernameBob Karting
    Jan 21, 2025
    63
    Rob Dyer
    Hi all,
    Just thought I would stick this up for any whose power steering pipes have split.
    Return pipe - I bought Gates SAE100 R6 12.5mm 1/2 “ original pipe was 12mm x 19mm, but could not find that - even the Mercedes Meyle 059 001 0001 tube that should be 12mm came through as 1/2” and yes I know 1/2” is 12.7mm but apparently most people think it is 13mm and Gates thinks it’s 12.5mm
    The Gates stuff seems to fit. The old pipe was 3.08m and I used about 3.2m of the new stuff to get a nicer routing around the ABS pump.
    The supply pipe I got from Maranello parts in the UK and was a bit peeved to pay £160 for a pipe marked up as 2009 that is probably actually older. It looks okay and has a warranty… if I figure out the end fittings size, I will post them here as you could get this made up cheaper. It is 2.5m long.
    Not too bad to fit, I took return pipe out first with rope tied to it so that I could pull new hose back through. But then replaced supply pipe first as the fittings are large. I tied the new supply pipe to old to use the old pipe as a pull through. Then I pulled the new return pipe through.
    My old supply pipe had worn through on the suspension turret bit. The new pipe seemed longer probably to avoid that happening again.
  2. JLF
    JLF Formula 3
    Sep 8, 2009
    1,711
    Thank you for the info.
    UsernameBob likes this.
